Old 03-03-2018, 04:40 AM
Default Re: Reason 8.1 not showing up in Pro tools 10.3.8
Originally Posted by fork-media View Post
did u get this solved?
just bit me. have uninstalled as per sweet water once..
then installed 10.3.10
still the same missing...
Do you have Reason running as 32 or 64 bit? For PT10.3.10 you need to have Reason running in 32 bit. Quite everything and do a 'get info' on Reason and select 'run as 32 bit' in the windowlet that comes up.
Old 03-04-2018, 10:05 AM
fork-media fork-media is offline
yes - thanks I should have clarified I had made sure it was running 32 bit..
I may try uninstalling everything. and going again
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 03-04-2018, 03:51 PM
Okay.And to answer the question you deleted - AppNap should always be disabled for everything. I think there's a Terminal command to do the deed to all the applications at one time.
Old 03-05-2018, 02:41 AM
hahah well caught - I put the reply and then thought I should google it.. so answered my on question..
got to blast something out this morning but may try the unistall
actually I realise that there was another plugin missing - Nugen Vis Lm2 - but reinstalling the plug in brought that back,
maybe I try deleting all the rewire stuff then reinstalling reason. altho that just seems to consist of dragging reason to the applications folder..??!
Old 04-14-2018, 04:55 PM
up4days up4days is offline
The OP stated in the beginning that he had been running it for over a year, so he HAD to have been in 32-bit or it wouldn't have run on 10 at all.
The Sweetwater directions that Jim posted is always the first solution to try when PT isn't recognizing plugs, cause it usually works! My power went out when my PT was open and then suddenly wouldn't recognize Reason, until it rescanned.
If you don't see com.avid.ProTools.plist in the Library-preferences folder then you are not in the right folder.. need to be in Home>Users> Library. Reinstalling PT is always a complete last resort and is unnecessary for 95% of problems especially for a one-plugin issue.
Old 04-15-2018, 04:35 AM
If you notice I was responding to fork-media and NOT the original poster.
Reason 8 ReWire not showing up in Pro Tools 11 maxgain macOS 6 03-29-2016 09:15 PM
reason 3 not showing up in pro tools 8 instrument list PointStudios macOS 1 10-05-2014 05:09 AM
Reason not showing the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-30-2010 06:22 AM
reason 3 not showing up as an instrument zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-03-2010 01:29 PM
Reason adapted not showing up Rizz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-23-2007 07:25 PM
