Old 06-01-2017, 01:21 PM
hanksinclair hanksinclair is offline
Default Re: Avid Artist Mix Replacement touch-sensitive rotary encoders
Thank you very much for your support, Eddie!
Old 09-05-2017, 12:19 AM
oortone oortone is offline
Originally Posted by EddieJones View Post
Note: This is unsupported by Avid and any damage to your unit is your responsibility.
To find out whether the encoder or the IC is the issue, with the unit running touch one of the larger Encoder solder mounts (the 2 either side, not the smaller pair or 3 at the top and bottom of the picture above).
If the touch works its the encoder that's faulty, if not its the IC.
The Encoder is an Alps EC11E24144 the IC an Atmel QT113B
Hello, this is a great help!
I have the older model MC Mix. I guess the same or equivalent encoders are used in that one too?
Anyway, I find the first four letters from the part number in Alps catalogue but I can't find an exact match. Any idea if there's an equivalent in this listing?
http://www.alps.com/prod/info/E/HTML...EC11_list.html
Apart from dimensions, is there some other crucial parameter that has to be the same on a replacement?
Old 09-07-2017, 12:06 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Its 24 pulses per 360 per phase but there are many different subtleties. I suspect these are special versions for Avid. You would have to contact Mouser or someone like that to see if they can get them.
Old 09-11-2017, 10:52 AM
I guess if I get dimensions about right, and pulses per rotation I would be fine. The rest should be more or less unimportant?
Old 09-11-2017, 11:37 AM
EddieJones's Avatar
This link was posted on FB https://www.digikey.se/product-detai...024-ND/4499668 (Not by me or Avid though but it looks Ok)
  #16
Old 09-28-2017, 04:15 AM
Thanks!
  #17
Old 11-16-2017, 10:42 AM
chrismeraz chrismeraz is offline
I just bought a brand new Artist Mix. None of the rotary encoders work well. They are all a jerky mess - I might turn one several turns and the value won't change, or I might give it a tiny nudge and the value changes drastically. I have the latest firmware. What else can be done?
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
  #18
Old 11-16-2017, 11:21 AM
EddieJones's Avatar
That doesn't sound right at all, just to confirm you are running EuControl 3.7 and PT12 ? Do the faders work OK ?
  #19
Old 11-16-2017, 11:49 AM
Hi Eddie,
I am using EuCon 3.7 and PT 12.7. The faders work fine, except they have a bit of spring back, so if I push a fader up to 6.0 for example, when I let go it will spring back down to 5.8 or 5.9.
Thanks for your help Eddie.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
  #20
Old 11-16-2017, 11:55 AM
EddieJones's Avatar
Alos is this with all controls (pan, sends etc.) ? A video showing this would help too.
Avid Artist Control Encoders - Can we make them linear? jvining Artist Series 4 10-11-2014 01:54 PM
Rotary Encoders randomly going into write colinweeks ICON & C|24 4 05-17-2009 07:59 PM
Are the rotary encoders touch-sensitive... Stig Eliassen ICON & C|24 2 07-31-2008 08:53 AM
Velocity sensitive vs fixed mode encoders. mixboy bob ProControl, Control|24, Command|8 4 10-08-2006 04:19 PM
Difference between motion sensitive and touch sensitive faders? bp78 Pro Tools TDM Systems (Mac) 7 07-03-2002 09:27 AM
