Old 11-09-2018, 08:00 PM
vsrecord vsrecord is offline
Default export list of music clips for cuesheet
I am trying to find a way to export a list of music clips so that a cuesheet can be assembled. Any ideas? workflow, software? Thanks for any help.
Old 11-09-2018, 08:19 PM
KingTor KingTor is offline
Default Re: export list of music clips for cuesheet
I haven't come up with anything....
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 11-09-2018, 08:38 PM
philper philper is offline
Couldn't you start by having a session that was only the music clips, then exporting as text?
Old 11-09-2018, 09:07 PM
In 12 (and later, I assume) you doubt even have to make a different session, you can export selected tracks as text. Whether this works depends on how you do things like faces in and out--I often leave long handles in the music tracks and do the fades with a fader, which affects the in and out points significantly enough that it's easier for me to just do the queue sheet timing manually. Fortunately, the midday supervisor will often do the cure sheet of you give them a QuickTime of the finished mix with a timecode window burn.
Old 11-09-2018, 10:08 PM
BScout BScout is offline
Create a dup track of your clip/cue placements against picture.
On the dup track, do strip silence (watch how the edits trim as you adjust the threshold)
Commit that for the dup track
Do an export session data for both timecode and mins:sec (two exports) for selected tracks and only select the dup track. You'll need both to do a proper RapidCue cue sheet (the current standard)
When you get the text files, import into a spreadsheet.
At this point, it depends on your spreadsheet abilities. I can be done with a properly formatted one in 20 mins but if you aren't familiar with how to import text to a spreadsheet for your spreadsheet program of choice, it'll take longer to learn (that includes how to split to columns, how to ignore spurious data, and how to set columns to the right data types and trim off extra spaces, etc.)
Old 11-10-2018, 01:34 AM
Pete Gates Pete Gates is offline
To the original poster my PG PT Session software (I think I'll get people on this forum to suggest names for my software, I don't have the imagination for that!) may do what you need. You'd need to explain in more depth what you're trying to do.
And to Scout, thanks, I didn't know about RapidCue, I've just downloaded the spec, will try and incorporate it.
Cheers,
Pete
Old 11-10-2018, 03:34 AM
thanks for all the suggestions I'll try some tomorrow. i'm trying to export a list of music used in a show for my client to build a cue sheet. clip name and timecodes for length are what they want. I only know time intensive ways to do this looking for simplest way
Old 11-10-2018, 04:26 AM
paulo m's Avatar
paulo m paulo m is offline
I do this all the time. Select the tracks that contain music only. Then choose Export as Text. In preferences choose only selected tracks and combine fades.
The only thing that I don´t like is that it will export results for both legs of a stereo file, thus duplicating each stereo track.
Then open in a spread sheet or other suitable program if you need to "polish" the presentation, add your company logo etc.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 11-10-2018, 04:27 AM
Yeah, my software should do that well enough, it's what it was written for originally before adding all the ADR stuff - which looks a bit scary, I need to hide it for music use but you can ignore most of it!
Pete
Old 11-10-2018, 07:57 AM
its2loud its2loud is offline
Split your tracks into mono. Delete, hide, or just select L or R side, and export session as text. Works every time.
HTML code is On
Export clips with fades jgiannis Pro Tools 10 3 03-17-2021 04:02 PM
Music cuesheet mihaicoporan macOS 3 04-04-2019 03:45 AM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Export Midi Clips txshonk Pro Tools 10 2 04-06-2013 08:28 PM
AV4.0 ADR Group Clips export alex weber Post - Surround - Video 1 06-23-2010 06:05 AM
