Old 01-12-2012, 11:58 PM
Default PT10 Bug: opt-command-/ doesn´t always work
since going PT10 I have to hit apt-command-/ twice sometimes three times till PT actually writes the automation.
This happens when using a soft-key on the artist control or the regular key-board.
It´s quite a bugger. I have moved to hitting the key-command like 4-5 times to make sure I don´t lose my settings when turning off preview.
Anyone seeing this as well?
Frank.
Old 01-13-2012, 05:01 AM
Postman Postman is offline
Default Re: PT10 Bug: opt-command-/ doesn´t always work
Maybe related to what I have seen and posted about earlier with bypass settings. Using opt-com-/ two times in a row has been working consistently for me. The first time it doesn't always write switches (like bypass) correctly. I've been wondering if there are instances when a 3rd time is required but I haven't yet noticed it.
Old 01-13-2012, 05:29 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
this is making me hold off on PT10 - I don't like automation clangers! i await PT 10.2 with baited breath.....
I am still sitting on the fence re converting my HD3 to Native and doing the whole lot at once (and Lion)...
cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
HTML code is On
Big problems getting Command 8 & PT10 to work oswansonlow Windows 5 03-03-2012 11:16 AM
Adat In on 192 doesn´t work kolo Pro Tools TDM Systems (Mac) 3 04-30-2006 06:04 AM
My legacyinterface doesn´t work! matsgranberg General Discussion 0 07-24-2005 09:27 AM
My two day 002 doesn´t work already!!! Punkest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2003 10:07 AM
It doesn`t work - on 3 different PC´s schrodis Digidesign Hardware & Software 7 11-09-2000 10:09 AM
