Old 01-27-2020, 09:33 PM
mandal mandal is offline
Default Re: 5-6 second delay when initiating record
Try to record to another disk...
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 01-28-2020, 04:18 AM
kw88keys kw88keys is offline
Thank you for your suggestion. I now tried recording to another disk with a new file and no change in the delay issue. I have a feeling that it is tied in somehow to my Windows 10 settings. I do not have any internal sound card activated so I don't think that would be the issue. Have gone through the Windows 10 optimizations but I think I will revisit and see if I missed something.
Old 01-28-2020, 07:26 AM
If you have an optical drive(CD or DVD), is there a disk in it? If so, remove the disk
Old 01-29-2020, 11:58 AM
Thanks for the input. There is no CD or DVD or memory stick in the system. I do have an external drive in a USB slot in which I use for back ups. I will try disconnecting that.
Old 01-29-2020, 03:58 PM
The Weed's Avatar
The Weed The Weed is offline
From your Sandra Report: "Removable Drive (A:) : N/A"
If you really have a floppy disk controller, go into BIOS and disable it.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #16
Old 01-29-2020, 10:06 PM
falcowe's Avatar
falcowe falcowe is offline
I had a similar issue with my orchestration template. It ended up being something with East West’s Play plugin running inside Vienna Ensemble Pro on a separate machine that was causing a 5-6 delay in my GUI catching up with where the session was playing back. But I think this is fundamentally different from you are experiencing since it seems like your delay nothing is recording where in my delay I was recurring but the GUI was frozen for that time.
  #17
Old 01-29-2020, 10:34 PM
I can see from the Sandra report that you are using AMD and not Intel - could that be the reason ?
Avid OMNI PCIe
  #18
Old 01-30-2020, 01:28 AM
I suppose it is a possibility. I do think though that from searching other posts on this forum that AMDs are running PT successfully. I did not have any issues when I was running on Windows 7.
  #19
Old 01-30-2020, 01:29 AM
Thanks for the reply. I do think this is a separate issue. Even when I place EW Play into the unused folder, the delay persists.
  #20
Old 02-01-2020, 04:01 AM
SUCCESS! It was the drive A in the BIOS setting. Drive A was disabled but it showed a configuration for a drive. I removed that configuration to show no drive and now the troublesome delay on both record and playback-after-record is eliminated and the functions are working normally.
Thanks much for the assistance!
delay when initiating record kw88keys Pro Tools 2019 0 01-25-2020 07:31 AM
press record.... delay... delay...now it records phanatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-20-2007 03:20 PM
delay when pressing record or stopping record mrufino1 Pro Tools M-Powered (Win) 6 03-06-2006 09:29 PM
9093 when initiating plug-ins pmh3r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-16-2002 11:29 AM
