Software Monitoring
I´m trying to find a good workaround for software monitoring in Protools - usually I set my prefs to send follows main pan but I´d like to have the same with the volume level because I have to send it prefade to the headphones of the musicians I´m recording (if not I cant listen into solo tracks while recording..)
how do you guys do this? |
Re: Software Monitoring
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
If I understand what you're describing, you want to send prefader mixes to your musicians... Select all the channels you want to send to the phones, and use 'copy to send' (edit menu). Then choose which send to copy to and check fader and pan. This'll copy your mix settings to the selected send. Then hold option+shift and click the 'pre' button in one of the sends and it'll set them all to pre. And you're done!
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
A very quick way to set up a starting point for a headphone mix is do a 'copy to send' of your main mix to all the sends - pre fader of course - you're using for the headphone mixes.
from that point on the whole idea is to customize the mix for the talent in the tracking room. Chris
Chris Lambrechts Applications Specialist- Live Sound |
thx guys didnt know there is copy to send - I´ll try it immediatly
it kinda stays grey in the menu.. cant select it and I selected all tracks before.. I´m using PT 10.0.1
I guess its HD only right?
Try highlighting the tracks and use shift-option to click on the send and it should put a bus on your selected tracks. In your i/o setup chose the output you want to use, and label it headphones. I usually use 1/2 to the 01V, and 3/4 directly out to the Powerplay XL.
Music is the Message |
Software monitoring and UAD | Sam C | Pro Tools 11 | 18 | 03-10-2018 08:03 AM |
Software Monitoring On/Off | captainhook | Pro Tools 9 | 253 | 09-28-2012 03:59 AM |
Software monitoring? | davey boy | macOS | 2 | 12-10-2010 09:53 AM |
Software monitoring question | mattrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-10-2008 04:43 PM |
monitoring other software through 001 | lethe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-05-2000 11:26 AM |
