Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 03-08-2019, 12:39 AM
belasoul belasoul is offline
Default Dock only after restart
After launching PT Ultimate 2018.12 most of the time the Dock is not activated. After restarting in EU Control software the Dock is available. I'm on 18.3..0.244
Any suggestion how the get it more stable?
MacOs 10.13.6, RME Fireface UC / UAD Apollo, PT Ultimate 2019.6
Mac Pro 6.1/12-core,64GB RAM, Aja t-tap
Old 03-09-2019, 06:45 AM
docric docric is offline
Default Re: Dock only after restart
Are you on a mac? With one or 2 ethernet ports?
What network (s) are you using? 5 GHz ?
Thanks!
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.5
PT 2019.6.0 Ult.
Burl MS / PT Dock/ Eucon 19.7.0/iPad Air2/ iOS 12.3.1/ProTools|Control
Old 03-09-2019, 08:22 AM
yes, mac pro 6.1 on 10.13.6
and yes 5ghz - the dock is connected to the ethernet port of one of the thundebolt displays.
thanks!
Old 03-09-2019, 08:44 AM
Originally Posted by belasoul View Post
... the dock is connected to the ethernet port of one of the thundebolt displays.
thanks!
You've probably already done this, but, if you look in the Apple Sys Prefs, under Eucon, what is it showing under the "Network Interface" dropdown? Are there multiple "Ethernet 1, 2, 3..." ? Is it showing "Ethernet 1" ? (not wi-fi)
(I'm not sure how this will work with multiple Ethernet ports on your displays- ours is connected to Ethernet 1 on our mac pro... it gave me all kinds of trouble when it was plugged into Ethernet 2)
-C' ya'
Rick
PT 2019.6.0 Ult.
Old 03-09-2019, 11:31 AM
There are the options: Ethernet1 , Ethernet2, Monitor-Ethernet.
It was put on Ethernet1, any suggestions?
The problem is that the EU Control Settings don't find the Dock directly after powering the unit. So i have to manually restart the EU Applications before launching Pro Tools. From then it works solid.
Old 03-09-2019, 02:53 PM
My issue was resolved when I chose "Ethernet 1" & was physically plugged into the Ethernet 1 port on the mac pro. (see below)
It's a shot in the dark, but try "monitor-Ethernet" ?? instead of Ethernet 1.
(not sure if "monitor" in this case is the label for the video monitor ethernet port that you're plugged into?)
Worse that happens is you have to change it back.
Otherwise, I'd try plugging your Ethernet cable from the Dock into Ethernet Port 1 on the Mac Pro (Left side port) & insuring you're still on "Ethernet 1" in Apple Eucon Sys Prefs. Plug your inet into Ethernet 2 (Right side port) and then use the display's Ethernet ports for any other network connections.
... The problem is that the EU Control Settings don't find the Dock directly after powering the unit. So i have to manually restart the EU Applications before launching Pro Tools. From then it works solid....
Yep, I totally get it ... had the same issue for quite a while.
Worst case scenario- contact Avid TS ... but only if you have a support plan.
Let me know if you get anywhere ... here's hopin'!
-C' ya'
Rick
PT 2019.6.0 Ult.
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Pro Tools | Dock 0 10-01-2016 08:20 AM
PT11 restart bburch88 Pro Tools 11 11 12-21-2013 04:29 PM
"you need to restart" HELP! Eless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-24-2005 01:37 AM
Restart DWdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-11-2004 01:14 PM
MIX 24 + G4 + Restart 2relaxed Pro Tools TDM Systems (Mac) 2 03-26-2004 09:02 PM
