Old 02-19-2005, 12:56 PM
RBaker RBaker is offline
Default Mixing for Music Video / TV?
I've been doing an album with a band and they just finished shooting a video. I need to give them a video mix tonight. (The record is going to be mastered in 2 weeks but this mix will not) Any tips on what I can do TODAY that will help it transition to TV etc? I guess I can listen on my TV. Anything else? Should I roll off low end? Are the certain frequency bands that are problems for TV speakers that I should watch for?
Never done this before...
Old 02-19-2005, 03:29 PM
Bastiaan Bastiaan is offline
Default Re: Mixing for Music Video / TV?
Roll off at 50 Hz or so.
Slam the living daylights out of it with a Waves L2 or L3. (audio for video usually has a dynamic range of about 3 db...)
That's basically it. Ask them at how you should deliver it. Use a calibration tone.
at work i use: 1 Khz at -18 dbfs
as maximum peaklevel, keep it at -9 dbfs. Yes..thats eating 9dB of headroom, but thats how they work.
Write on teh DAT or CD:
Tone: 1 Khz, -18 dBfs PPM
Macximum program level = -9 dBfs
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-19-2005, 03:30 PM
Also the best thing is to check your mix on an actual TV....
What's that?
Bastiaan
Old 02-19-2005, 04:07 PM
KingFish KingFish is offline
Definately listen through TV, which you, and Bastiaan have already covered, also, i generally do a much more "Mono compatable" mix for television, mixing main parts that have been Hard Panned on the record to 10'oclock / 2 o'clock in the mix spectrum.
Check for, and deal with any mono phasing that might be going on, and effects levels in mono.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Mixing to video: Video refits and mix amendments DFN Post - Surround - Video 6 02-26-2014 10:56 AM
Mixing music in 5.1 for fun jdogric12 Post - Surround - Video 3 02-21-2013 11:13 AM
Mixing Legacy Music coolcat Pro Tools TDM Systems (Mac) 3 01-05-2007 03:48 PM
MIXING HIP HOP & R&B MUSIC 7 MO-BEATZ Tips & Tricks 4 06-14-2005 11:16 PM
music packages for music video shoots cwholden Post - Surround - Video 0 03-07-2005 01:37 AM
