Old 10-07-2019, 02:35 PM
Deerebanks Deerebanks is offline
Default Help! Pro tools 12 playback slow and offbeat when I reopened the session
So I am new to pro tools 12. I was still using 7 and decided to make the jump cause nothing was compatible with it anymore. So I went to record vocals for the first time and everything went smooth. Sounded great! I saved it and closed the session so I could mix it the following day. I open it up the next day and everything sound off. It was slow and offbeat. Why did this happen and can I fix it? Or do I have to record it again? Did the clocks not match up? Really have no idea
Thanks
Windows 10
Pro tools 12
focusrite scarlett 2i2 3rd gen
Old 10-07-2019, 02:42 PM
Led Led is offline
Default Re: Help! Pro tools 12 playback slow and offbeat when I reopened the session
If you are using the Scarlett for your windows desktop sound, it may have taken over and changed the sample rate possibly? If you recorded in PT at 48K and windows is running sound at 44.1 it would play back slow.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 10-07-2019, 02:48 PM
So how would I change that?
Old 10-07-2019, 06:03 PM
So I checked and both were set to 44.1K I have no idea what to do. Can I salvage the session?
Old 10-08-2019, 09:48 AM
The Weed's Avatar
The Weed The Weed is offline
Find out what sample rate the actual wave file of the vocal is. If it's 48 as suspected, import it to a session with a sample rate of 48 and see if it plays back correctly. But be sure the Scarlett is NOT being used for Windows sounds/audio and that it's set to a sample rate of 48 first.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-08-2019, 10:08 AM
Thank you! I did check last night and everything that I checked was set at 44.1 but I did not look at the actual wave file.
I did end up re-recording it. And it seemed like everything went fine. I closed it and reopened it and it was correct.
Reopened a session in PT10 YYR123 Pro Tools 11 3 07-31-2013 07:46 AM
pro tools 9.0.3 session files freeze after reopened temrep Windows 12 08-29-2011 12:37 PM
Pro Tools Playback slow / skipping on Macbook Pro elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-08-2010 03:34 PM
reopened session sounds different sean c Pro Tools TDM Systems (Mac) 6 08-11-2007 01:00 AM
offbeat: how long can you go at it? freakuincy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-13-2001 10:19 AM
