Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-29-2019, 03:25 PM
metalmcguire metalmcguire is offline
Default Dante Outputs Not Showing Up
Currently running Pro Tools 2019.10 with Dante Virtual Soundcard. My goal is to be able to record band rehearsals and run them back thru the Yamaha M7CL track by track at a later time to train my team of sound volunteers. I have it working well using Waves Tracks Live but would really like to do the same thing thru Pro Tools.
For some reason, the separate outputs show up in I/O setup window but not on the individual tracks. I'm sure it's something simple that I just can't see at the moment but I've tried quite a few different things and can't figure out why they're not showing up.
I've attached some pictures to show you guys what I'm looking at/talking about.. Let me know if any other screen shots/information would be helpful to diagnosing this issue with me.
Thanks in advance!
MacBook Pro (Mid 2015) 2.8Ghz i7 16GB RAM
Apollo Twin Duo
macOS Sierra 10.12.6
Pro Tools 2019.6
Old 12-02-2019, 12:17 PM
Default Re: Dante Outputs Not Showing Up
Works fine here. What's on your bus page of the I/O setup? Looks like you set up just busses but not actual outputs. Hence nothing but the audition path in the drop down output menu.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 12-14-2019, 07:19 PM
You might try deleting the stereo routing I see in the IO setup window and make 32 MONO ins and outs Another possibility; is EVERYTHING clocked to a single master? On my system, when I had inputs coming in via ADAT, if clocking was not correct, the ADAT paths were not available
Pro Tools Dante Outputs Not Showing Up metalmcguire Third Party Interfaces 0 11-29-2019 11:47 AM
M-audio firewire 410 not showing outputs in MP9 Reggie TAE Pro Tools M-Powered (Mac) 2 04-23-2012 07:44 PM
Structure - Outputs Not Showing Up dwaynedelario Virtual Instruments 8 06-20-2011 05:53 PM
not showing outputs for saffire 24 dsp bmenchen Windows 1 06-14-2011 11:17 AM
Windows 7 crash problems, mbox outputs not showing. The Blue Peanut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-05-2011 02:56 AM
