Old 07-20-2010, 03:47 PM
sean shannon sean shannon is offline
Default Re: Which motherboard/processor for pci cards?
What do you guys think of this one?
http://www.tigerdirect.com/applicati...168&CatId=5195
Intel H55HC Motherboard. 3 PCI slots, and it doesn't look like there is anything that would obstruct the cards.
Check your mix in mono.
www.mixingtheband.com
Old 07-20-2010, 04:31 PM
Fullsound Recording Fullsound Recording is offline
Yea maybe so on that one, make sure that SATA plug is not going to be in the way of the card tail.
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
Old 07-20-2010, 04:39 PM
Stickmanly Stickmanly is offline
I've got the flex cable running across just fine...Will try to post picts soon. If your looking for the LE -it seems to be in stock here:
http://www.compuvest.com/Desc.jsp;js...05?iid=1077712
Good luck!
Old 07-20-2010, 07:58 PM
x9blade x9blade is offline
Originally Posted by sean shannon View Post
I was hoping someone has a modern, available system recommendation, as I need to get a motherboard/CPU right now,.
this is the problem,pci cards are not even close to being modern
also, the pci to pcie upgrade is just unrealistic
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 07-20-2010, 08:14 PM
Thanks for that link. I am going to CompUSA tomorrow to check out the Intel motherboard, and we'll see if it works with the cards. They also have the one you are using, the ASUS P7P55D PRO, so I have that option too.
  #16
Old 07-20-2010, 08:51 PM
Andres Gonzalez Andres Gonzalez is offline
Originally Posted by Stickmanly View Post
...If your looking for the LE -it seems to be in stock here:
This is the only place I can find that has the LE version--newegg does not seem to have it. Newegg does have an LX version. Anyone know if this one has the required clearance? --it appears to
-Andres
  #17
Old 07-28-2010, 11:46 AM
OK. Went with the Intel DH55HC motherboard, 3 PCI slots. Works fine with Windows 7 and an i7. Cheers!
  #18
Old 08-10-2010, 09:40 AM
Lando Lando is offline
I have installed pthd 2 on a mobo Intel P7P55DLE with Intel i7: be careful to use only the LE mobo of the P7P55D family !!! The other mobos have a thik stellar heatsink of the P55 chipset so is impossible to' insert the Pci card in the slots.
  #19
Old 08-10-2010, 11:12 AM
pjplayer pjplayer is offline
i also had success with P7P55DLE and hd1. however, the core card refused to play if i had my firewire / usb combo card plugged in to the pci bus. not really a problem, but it did freak me out for an hour or so.
  #20
Old 08-18-2010, 09:28 AM
Mixchump Mixchump is offline
Just did a build with an HD2 on a Gigabyte GA-P55-UL3R, but it wasn't my first choice...
I was hoping to find a GA-P55-UL3D which has 4 32-bit PCI slots together, but NOBODY up here has stock on this board. Was there some big recall or something? I was hoping there would be some feedback on this board... I'm really hoping to find a board that will do at least 4 PCI slots and still run an i7 CPU.
BTW,
Is it sacrilege to take a dremel tool to the seemingly unnecessary extra bit on the Digi cards that go beyond a 32bit slot? Even if I'm careful, and the card continues to work for another 3 or 4 years, will I be SOL when it comes time to trade in the mangled card?
Cheers for now, eh?
PT 7.4 with new motherboard and processor KGB2011 Pro Tools M-Powered (Win) 8 09-01-2009 08:37 AM
Help!!!! Motherboard and Processor Obscene Pro Tools M-Powered (Win) 2 03-07-2006 11:46 AM
Help!!!! Motherboard and Processor Obscene 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-07-2006 11:37 AM
new motherboard and processor abel quintanilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-22-2005 08:45 AM
motherboard processor help 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-25-2001 06:59 PM
