Pro tools HD or HD Native advice please
Hi peeps
Hope a few people can give some advice about 2 weeks ago i was planning on selling my 003+ le system and buying pro tools HD pci. At the mo i use all rtas plugins and dont want to upgrade them all to TDM (cost factor) and i use a PC windows xp. I was going to build my new PC with i7 and gigabyte mother board which a user on this site has been using and had no issues. The question is Pro tools Native has just been released and seems to be the answer to my pro tools dilema AHHH but is it. I can pick up a pci HD2 rig and build a new pc for about £3000, where as pro tools native will cost me around £5000. ADC is my biggest issue. is the ADC in pro tools native just as good as HD and would HD2 out perform PTN using rtas plugins. also pro tools native only works on windows 7 and quite a few of my plugins are not supported on windows 7 which makes me think PT HD is more viable for me. When i ring shops up and discuss it with them i alway think they want to make money so they tell me what they want me to buy from them. therefore im here for some unbiased info Thanks |
Re: Pro tools HD or HD Native advice please
I think your answer is right there... The HD2 system will get you all you need, and it won't devalue as soon as you "drive it off the lot"... That kind of $$ for HDN is just insane. Just my 2c... but it IS my 2c...
-C' ya' Rick MacPro 7,1; 16 core OSX 13.5.2 PT 2023.9; Eucon 2023.6 Dock/S1/2x iPad |
Thanks Docric, does ADC work when you use RTAS plugs in HD just the same as it would with TDM
My 2c worth.
The system in HD NATIVE will have to run EVERYTHING via the CPU. That is Plugins and Mixer and busses and outputs etc. Where as the HD2 means that only the RTAS plugins etc will run on the CPU and the MIXER, Busses etc plus any TDM plugins you get with the system such as DIGIRACK etc only use the DSP on the HD2 cards, so in effect the HD2 will give you more RTAS power available. The only real limiting factor is RAM, but there are ways around that one as well. For the dollars I'd be going HS2 plusinterface..-192 if you can afford it. Best regards, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
... until the new TDM cards come out...
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
This is all true, however, where HD Native will shine is that you can effectively use more voices than a HD system. On a HD2 if you put a couple of RTAS plugins on Auxiliary channels, you will eat voices really quickly (extra 2 voices per stereo Aux). If you are working at 88/96k you will then have to allocate 4-5 DSP chips for enough voices for the engine (64 voices). Add delay compensation here, and you start to actually hit the TDM limit of a HD2. On HD Native, this won't be the case as putting RTAS on Aux doesn't eat the voices up, hence you can actually run more voices on a HD Native system if using RTAS plugins on Auxiliaries. The max voice count on a HD Native is truly the limits of Protools, not reduced becuase of the insertion of RTAS plugs on Aux channels. So you truly get 96 voices @ 96khz. This is great if you are doing mixing only I reckon. cya Ghengis
Intel I7-930 Asus P6T-Deluxe V2 6gig Triple Channel 1600mhz HD2 PCI, 96 I/O, Command-8 Win7x64 |
HD native will be way more powerful then an HD2 accel. Hands down. On an HD 2 accel, if you want 192 voices, that's 6 DSP chips. Add delay compensation, thats probably about the same or a little less if you use short delay comp. There are 18 chips on an HD 2. So, we have used 10, let's say, just to get full track count and delay comp going. We haven't even built the mixer yet. So depending on the mixer needed, let's say it's a simple mix, 2 chips for that but the mixer will probably take up more chips in a 192 voice session. So, we are at 12 chips or so leaving 6 DSP chips at the most for plug ins. That really isn't too many plug ins but if you are just thinking EQ3 you can probably put one on every channel and have a littel DSP left for a limiter or something. Not a lot of power.
HD native, full voice count, full mixer, full long delay comp, right of the bat and I dought you are braking 5% CPU. I think I can run 490 Dverbs with my computer. That's like a HD 13 or so. All available to use without using voices. I think we have a clear winner. |
He's buying a PCI TDM system, that means "used"...
regardless of "new tdm" cards, the relative value of the pci cards is still going to stay pretty close to the $800-1K current. Maybe it drops $300?? That's still a lot less of a difference then the price diff of buying a $5000 HDN (or a $3000 new HD"mega-mocha-grande'-accel3+" card).... vs a PCI HD2
I had an HD2 system a few years back, and it was great. I did a lot of pop and rock stuff with it and I can't ever remember hitting a wall, although an HD3 is probably really where it's at. HD is power on demand, and I still love it. Love those INPUT buttons too, the new interfaces are killer, and HEAT...wow! TH |
Need advice on HD Native | jdsaviator | Pro Tools HDX & HD Native Systems (Win) | 12 | 01-28-2014 08:28 PM |
I'm considering HD native, but need some advice... | RedPrint | Pro Tools HDX & HD Native Systems (Win) | 10 | 11-24-2013 04:59 PM |
Advice on HD Native | thesuitelounge | Pro Tools HDX & HD Native Systems (Mac) | 5 | 05-01-2013 01:26 AM |
Looking at new Mac Pro and upgrading to HD|Native. Advice from those using Native? | Belegur | Pro Tools HDX & HD Native Systems (Mac) | 5 | 04-18-2012 06:44 AM |
