Old 11-20-2010, 03:17 PM
paul_g paul_g is offline
Default Tracking Levels and Playback Levels
I noticed that the tracking level is much lower than the playback level.
Example, I tracked a b3 player + b3 solo. Sounded great, but when I played it back, it was clipping and much louder on the playback from when we tracked.
I notice when I track something I have to turn up the fader, and on playback turn it down...
This issue inevitably led to me having 5 different takes of very good solos almost unusable because of clipping....
Now, is there a plug, (I'm trying some compression), that will assist in reducing the clipping?
Mid-2007 2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.3.10
PreSonus DigiMax FS
Dynaudio Monitors and KRK Sub
Line6 HX Stomp
Old 11-20-2010, 04:24 PM
GTBannah GTBannah is offline
Default Re: Tracking Levels and Playback Levels
Unfortunately, I don't PT does not allow us to monitor the input level via the software. We have to do that via some hardware option.
I could be wrong, but that's my understanding.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 11-20-2010, 04:26 PM
I could be wrong, but that's my understanding of the situation.
Derrkins
GuyBarTola
Old 11-21-2010, 10:18 AM
Que???
Not sure of your answer GT. I'm just talking tracking in general.
When I record I hear the thing I'm tracking in the cans or monitors - sounds fine.... then on playback it's way louder. Resulting in me having to grab the fader and drag it down.
I'm fearing that I'm not getting a 1:1 db ratio when tracking vs. playback, which in my case lead to something I thought was good, but turned out to be digitally clipping on the playback.
PreSonus DigiMax FS
Line6 HX Stomp
Old 11-21-2010, 11:43 AM
Originally Posted by paul_g View Post
Que???
Lemme go out on the proverbial limb here ....
My understanding is, that there is no input monitoring in PT. What we hear in the cans, sounding good, is probable very hot going into PT, so when we hear the playback, it's distorted. If we had input monitoring, we would have been able to see how got the recording levels were and make the adjustment.
Again, I could be wrong about PT's not having input monitoring.
Derrkins
GuyBarTola
Old 11-21-2010, 02:26 PM
Interesting. What I hear on recording is exactly what I hear on playback. Have you made record and playback disconnected from each other somehow? Are you using Pre-fader or Post-fader metering?(should always use PRE for recording).
Old 11-21-2010, 03:33 PM
anothercolour anothercolour is offline
In the Preferences pages you can choose to Link Record and Play Faders. Maybe you have that deselected.
Old 11-21-2010, 05:06 PM
The Dougfather The Dougfather is offline
Clipping occurs at the AD stage so once it's clipped the audio is damaged so to speak, in analogue you could get away with it, in digital it's nasty stuff. You would need a hardware compressor before the AD stage to truly reduce peaks on the way in. If you apply a compressor after audio has been peaked during tracking the meter might not clip but the audio has already clipped, so it's false economy.
Your using a 003 right? Do you have low latency monitoring enabled? If so LLM disables plugins and sends on record enabled tracks. Is it possible the quietness during tracking is the plugins bypassed and the loudness them being re-enabled at playback, taking a stab here.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 11-21-2010, 06:48 PM
One thing I have to ask; how hot are you recording(where are the meters while recording)? it you are shooting for as hot as possible, that's not a good idea. It worked well in the old analog days(to get above the noise floor) but now we have almost no noise, so record at 24 bit(whenever possible) and get the meters just into the yellow(plenty of headroom this way). Old habits die hard(since I started on a 16 track 2" machine, I know them well)
Old 11-26-2010, 06:37 PM
I shoot for nothing higher than -6db... Since I record at 24 bit, I have a lot of head room to play with. I'd rather track really low and then mix high. Yes, going form analog (giving my age away) to digital was a switch at first, but I know now I never go higher than -6db (that's my ceiling).
I'm afraid the b3 player cranked his volume during a solo and I wasn't looking at the levels... So I've limited (with look ahead), and some creative eq - plus more compression and I think I'm ok. It was bad, luckily not that bad, but in this case bad enough, but non the less, I think it's buried in the mix.
A mistake I will NEVER make again... (taking my eyes off the meters during a solo section).
PreSonus DigiMax FS
Line6 HX Stomp
Appropriate Levels for Tracking and Analog Summing anothercolour Tips & Tricks 14 02-26-2014 05:49 PM
Creating the best mix levels / playback levels universe777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2006 11:49 PM
Tracking Levels Question... JB3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-30-2002 03:01 PM
How hot levels do you go for when tracking into PT. flymax Tips & Tricks 49 06-24-2002 06:01 AM
Tracking levels - using pads v.s. not where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2002 08:25 AM
