Strange Error..
Thu Oct 23 18:57:12 2008
panic(cpu 1 caller 0x001A8CEC): Kernel trap at 0x06374307, type 14=page fault, registers: CR0: 0x8001003b, CR2: 0x00000000, CR3: 0x00d06000, CR4: 0x00000660 EAX: 0x069b2900, EBX: 0x07491a00, ECX: 0x00000000, EDX: 0x069b2a00 CR2: 0x00000000, EBP: 0x54b53b68, ESI: 0x08417740, EDI: 0x00534078 EFL: 0x00010202, EIP: 0x06374307, CS: 0x00000008, DS: 0x069b0010 Error code: 0x00000002 Backtrace (CPU 1), Frame : Return Address (4 potential args on stack) 0x54b53968 : 0x12b0fa (0x459234 0x54b5399c 0x133243 0x0) 0x54b539b8 : 0x1a8cec (0x4627a0 0x6374307 0xe 0x461f50) 0x54b53a98 : 0x19eed5 (0x54b53ab0 0x216 0x54b53b68 0x6374307) 0x54b53aa8 : 0x6374307 (0xe 0x69b0048 0x54b50010 0x5b0a0010) 0x54b53b68 : 0x5c10c483 (0x7491a00 0x0 0x54b53b78 0x124) 0x54b53b88 : 0x3eb72c (0x747db00 0x534078 0x1 0x120fc5) 0x54b53ba8 : 0x3f0387 (0x747db00 0x534078 0x54b53bf8 0x3eb799) 0x54b53bd8 : 0x3f0242 (0x8417740 0x0 0x1 0x0) 0x54b53bf8 : 0x3eb72c (0x8417740 0x0 0x1 0x1) 0x54b53c18 : 0x3eb7f9 (0x8417740 0x0 0x54b53c48 0x3eb72c) 0x54b53c38 : 0x40a47c (0x8417740 0xffff 0x8411c04 0x3eb7f9) 0x54b53c58 : 0x40a4af (0x8411c00 0x216 0x54b53c98 0x653f6a0) 0x54b53c78 : 0x3eb72c (0x8411c00 0x0 0x1 0x1e) 0x54b53c98 : 0x3eb7f9 (0x8411c00 0x0 0x54b53ce8 0x0) 0x54b53cb8 : 0x1874ea (0x8411c00 0x8380834 0x1e 0x54b53ce8) 0x54b53d08 : 0x12d195 (0x653f6a0 0x679d5a0 0x4 0x11d975) Backtrace continues... Kernel loadable modules in backtrace (with dependencies): com.digidesign.mbox2.driver(7.4.2f1)@0x5c106000->0x5c127fff dependency: com.apple.driver.AppleUSBMergeNub(3.0.7)@0x5bfdc00 0 dependency: com.apple.iokit.IOAudioFamily(1.6.4b7)@0x5b01b000 dependency: com.apple.iokit.IOUSBFamily(3.1.5)@0x5b09d000 BSD process name corresponding to current thread: Safari Mac OS version: 9F33 Kernel version: Darwin Kernel Version 9.5.0: Wed Sep 3 11:29:43 PDT 2008; root:xnu-1228.7.58~1/RELEASE_I386 System model name: MacBook4,1 (Mac-F22788A9) I was using PT's for a short while before closing program, disconnecting the mbox and then posting a EQ question on forum..then when I went to close safari computer froze and had to hold power button down and force shut down. When I rebooted the error log above was displayed.. |
Re: Strange Error..
I get these all the time. Only after i got a new logic board from Apple tho. They wont sort the hardware out because I'm not under warranty anymore.
The problem can be anything, normally it just says it was a kernel task. Doesn't always happen when the Digi hardware is plugged in as well. Can happen anytime. Thanks |
Re: Strange Error..
Re: Strange Error..
thanks for the reply digi support..I am just happy to know I don't have a hardware malfunction or something that needs replacing in my recently purchased mbox and mac..I thought I saw a thread floating around somewhere saying I should connect and disconnect only when the mac is off to prevent this "kernel panic" or whatever it is..thanks again.
strange error | karmacrew | Pro Tools TDM Systems (Mac) | 0 | 03-21-2012 02:47 PM |
Strange Error | ultrajoebot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-28-2008 07:58 AM |
Strange error - help? | mrculpa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-29-2004 06:50 PM |
Strange Error | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 0 | 07-01-2002 02:30 PM |
Some strange error! | skeeboheebo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-06-2001 10:13 PM |
