"Bootable partition in table" message when bootup hangs on Profile
System worked for over a week.
Today upon connecting to a different surface, at a festival, the boot process couldn't get past the blue digidesign screen. After the show (I used the locally provided Local Rack as well as the above mentioned surface), I tried again with my Waves license USB NOT in the hole by the power switch on the local rack, and it booted up. And stayed on when I put the USB in for the Waves licenses. I've started Venue Local Racks with this USB drive in various holes over a hundred times... I've scanned the USB for a virus, Norton not finding any. System: Avid Profile, 5 dsp cards. Ilok in one USB hole. Waves USB in another. Sorry, I don't know the versions or firmware, but I presume it is up to date is it is a major vendor. Europe power. Also I noticed the UPS was cycling occasionally, though the video screen never looked funky or any other symptoms of shoddy power. Any ideas on what happened? If it is likely to work tomorrow? Things I should try? ... etc. Thanks in advance, Denny |
Re: "Bootable partition in table" message when bootup hangs on Profile
So was the problem while using a festival surface and your touring local rack? Or...
Looks like your system is trying to boot from USB. Didn't ever saw that.
Maybe BIOS battery is low... But if so, you'll rather see checksum errors. |
Pro Tools 10.3.8 hangs at "Setting up I/O paths... Analog 1-2" [RESOLVED] | spmusik | Pro Tools 10 | 15 | 06-03-2014 07:22 PM |
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" | georgelegeriii | Pro Tools TDM Systems (Mac) | 0 | 11-19-2012 12:14 PM |
Pro Tools "install hangs at Installing Digidesign hardware drivers" | Bulley | Pro Tools M-Powered (Win) | 12 | 08-16-2012 07:53 AM |
"user profile too old..." error message | DaveBMusik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-16-2010 10:02 AM |
System Hangs on "Creating DAE Objects" In Vista 32 w/ Digi003 | Rostafunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2009 02:18 PM |
