Old 12-02-2000, 02:34 PM
XCLAIM XCLAIM is offline
Default Sound Replacer Drum Samples
Any suggestions where to buy or find a great collection of Rock snare or kick drum samples for use with Sound Replacer
Old 12-02-2000, 03:53 PM
adam_w1 adam_w1 is offline
Default Re: Sound Replacer Drum Samples
Both the Bob Clearmountain drum sample CD's
are pretty good. Not (cough) that I'm the kind of guy who'd replace your kick drum when you're not looking. Ahem.
life is too short for bad mixes.
online mixing
mixing coach
Old 12-04-2000, 08:22 AM
knewbee knewbee is offline
But most, if not all the samples on that CD have extensive velocity switch info in them. I'm not sure how that would affect using sound replacer. You'd probably just have to pick one sample to use. Unless Sound Replacer is intelligent enough to do velocity switch stuff on it's own.
Is it...?
Old 12-04-2000, 08:36 AM
i-listen i-listen is offline
It does handle velocity, in it's own way. You can set 3 different samples to 3 different peak settings from the original waveform. What I'll do is record say, a snare sample at soft, medium and hard velocities. I'll then set the 3 threshold levels in SoundReplacer accordingly. You can also turn on a "match peak" setting and you get even more dynamic movement between the 3 samples. Way cool.
Old 12-04-2000, 07:50 PM
ratz ratz is offline
I use the Clearmountain sample CDs... works great!
Old 12-04-2000, 09:21 PM
lwilliam lwilliam is offline
On my sampler, I've used the Ilio Double Platinum Drums as well as the Peter Erskine samples.
I don't have the BC disks, so I can't compare, but the above are nice - especially the DP Drums.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 12-05-2000, 01:29 PM
bluemt bluemt is offline
Anyone know how I can convert my Kurzweil formatted Clearmountain Drum CDs and Akai drum CD's to .wav or Sd2 for use with Sound Replacer?
Sorry to stray off topic.
Old 12-05-2000, 06:16 PM
Juergen Juergen is offline
Does anyone know where I can find sample cd's online, at good deals? The Clearmountain cd for example...
Thanks!
Juergen
Old 12-05-2000, 07:23 PM
sidereal sidereal is offline
bluemt....
There's a software utility called Osmosis that should be able to make the conversion.
You guys might also want to try Sound Dogs for drum samples. Apparently they sell individual samples rathar than full libraries, although I've never bought from them.
Old 12-07-2000, 02:25 AM
Bill Rigby Bill Rigby is offline
Sorry to stray off topic,but you guys seem to be interested in the sample side of life, has anyone heard the Mirislav Virtuos classical collection for Gigasampler? Always on the lookout for the `ultimate` Orchestra. I live in Australia and the only way to get it is over the net... about $3000.00 Aus (Crikey!)
Dont want to buy it before a thorough listening
Thanks in advance
Bill
Drum samples for Sound Replacer Blackers The Drum Room 9 02-12-2018 05:06 PM
Making Drum Samples from CD for Sound Replacer/Drumagog? millzboy Pro Tools M-Powered (Mac) 1 06-10-2010 03:54 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
What Drum Samples for 'Sound Replacer' Plug-in? mach-1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-07-2005 08:06 AM
