Old 11-02-2009, 01:37 PM
kcurry kcurry is offline
Default Midnam Problem
I am having a frustrating problem with a midnam file and PT8 on a Macintosh. At least a year ago I created a midnam file for a Roland Fantom-X7 and created an associated middev. After the usual nightmares, I finally got it all up and working. I've been using it to get patch names for quite a while now without a hitch. I recently decided to replace my hard drive and have been migrating pro tools 8 to the new drive. I've got everything up and running except that now the patch list does not show up. I simply copied the file that I have been using to the appropriate location on the new drive. I did MIDI setup and set up the Fantom-X7 with no trouble and the device shows up in Pro Tools, I just can't get the patch list to come up. When I use the file dialog to attempt to open the patch list, I can select it, but nothing happens, I still don't see my patch names. Has anyone here had a similar experience? Is there perhaps some setting I have forgotten about? I would pull all my hair out, but I don't have much left...
Old 11-02-2009, 03:16 PM
flommer flommer is offline
Default Re: Midnam Problem
Take a look at your .middev file and make sure the Fantom is in there. Also make sure it is spelled exactly the same way in the .midnam and .middev files
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-27-2010, 08:25 AM
Zoduati Zoduati is offline
Hi, i also have a Fantom X7 and trying to learn how to get its Patches displayed in Pro Tools 8. Would you mind pointing me in the right direction... or... if your patch files are something you may be willing to share..?
All quite new to me.
thanks,
Geoff
Old 12-30-2010, 06:40 AM
HeavyCut HeavyCut is offline
I am also having problems with this, I downloaded the appropriate midnam file but don't know where to put it so Pro Tools will show all the patches from my Roland Fantom.
Can anyone help?
Thanks!!
Xp-30 midnam Meneer Windows 1 06-22-2011 11:35 AM
Midnam problem with Emu Proteus/1 nedorama MIDI 0 10-07-2006 08:20 PM
Patch Name List (.midnam) Problem JohnDough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2004 02:42 PM
New midnam for XP-80 to try out Chris Cavell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-26-2004 11:13 AM
Please Help! Loading midnam file problem hongz1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-23-2003 09:42 AM
