Old 10-18-2004, 01:07 AM
francois's Avatar
francois francois is offline
Default what\'s the best way to set up my G5 Hard drive
Hi I have 2 internal drives in my G5 2ghz
One IDE 160 and a SATA Raptor 76 gig
Which one should be the system drive?
Thanks
Francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 10-18-2004, 06:19 AM
kcurry kcurry is offline
Default Re: what\'s the best way to set up my G5 Hard drive
You should set up the 160 GB IDE drive as your system drive and the Raptor as your audio drive. The Raptor is a 10k rpm drive. You should use your fastest drive for audio. The 160 drive is probably also SATA if it came from Apple, but it is 7200 rpm at the most.
Old 10-18-2004, 06:01 PM
francois's Avatar
Thanks Kcurry
Francois
Old 10-18-2004, 06:42 PM
surroundguy surroundguy is offline
Are you sure it's an IDE drive? You have to modify the G5 to get an IDE (PATA) drive into it, by hijacking either the slower ATA-100 bus used by the CD/DVD drive or by using a PATA/SATA converter. Both of those mods are a very bad idea for an audio system.
I would go with Kcurry's suggestion if the 76 gig Raptor SATA drive is going to be big enough for your audio. You can always use the 160 gig as a backup as well as for your system drive.
Alternatively, drop another SATA drive in there. You can get a 200 gig Seagate 7200 rpm SATA drive for $110.
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
