Old 05-27-2012, 12:13 PM
Broadsneakers Broadsneakers is offline
Default BFD2-Initial Groove start is noisy.
Hello everyone,
When I initialise BFD2 as a plugin, load a kit and then select a groove to play (doesn't matter which groove), before the groove plays back I hear a fast digital sound for about 2 seconds. After the initial noise, BFD2 works normal. This phenomenum only occurs in Pro Tools MP9. BFD2 In Cubase Elements 6 or as a stand-alone application, all is OK.
Any Ideas?
Thanks
Old 05-29-2012, 09:31 AM
Default Re: BFD2-Initial Groove start is noisy.
Hello everyone. The last FXpansion update 2-3-0-38 caused BFD2 to make unwanted noises. With update 2-2-2-3 all is working well. I can't say this is a BFD2 problem because I'm not getting any replies from FXpansion! On the other hand it is unlikely that Pro Tools 9MP has caused this bug. Hope this will help others. Wish you all well.
PS. Same problem with BFD2 ECO - don't use the update 2-3-0-38
Do I need to buy BFD2 or BFD2 upgrade if I have BFD ECO? joedexter23 The Drum Room 26 07-23-2012 11:38 AM
BFD2 or BFD2 upgrade from BFD ECO?? joedexter23 Virtual Instruments 2 03-11-2012 12:42 PM
PTMP 8.0.3, PT Crash When Dragging Groove from BFD2 into PT Region Editor kafka Pro Tools M-Powered (Win) 5 04-02-2010 08:14 AM
noisy start-up then quiting on pro-tools dijitalhorse Pro Tools M-Powered (Mac) 10 05-18-2009 01:58 PM
Can't start PT LE 5.3.1 on initial install - XP zagood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-12-2003 05:12 AM
