SOLVED!!! A couple of 11R glitches
First of all, love the 11 Rack. Just need your help/suggestions with the following glitches that have happened recently...
1) 11R dropped a cab setting when I was rig balancing. Set up a new cab in the rig, saved it. When I went to balance, the rig was very obviously running the old cab. Went back to the patch, and the old cab was back. Went through the process a couple of times, same thing happened. 2) Had a rig go completely silent on me. Everything shows up/appears normal, but no output. Had to copy in a saved version of the patch from another rig location. 3) The output volume dropped significantly on previously balanced and saved rig - I hadn't made any changes. Anyway - have you guys noticed your 11 becomes "unstable" over time? I love this thing and have used it regularly to gig over the last year. Need to be able to rely on it. Thanks! Last edited by mullenski; 07-29-2013 at 07:13 PM. |
Here's what caused #2 and #3:
During sound check (we play to a click), I set up the tempo for the two patches. Before switching patches for the next song, I saved the patch to retain the tempo I'd just tapped in. HOWEVER! I also use a midi foot controller and had the volume pedal all the way off in one case (#2) and halfway off (#3) in the other. The 11 Rack saves the position of the volume pedal also! So, nothing wrong with the 11R. Just learned a lesson that when you save a rig, you are saving everything - including what your midi foot controller is telling it to do at the time. That ends our public service announcement! |
Re: SOLVED!!! A couple of 11R glitches
I believe that there's a setting somewhere for "persistent volume"...
OP: check out page 93 of the user manual for full detail. http://akmedia.digidesign.com/suppor...v90x_71670.pdf
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhh hahhahahahaha, I learned this the hard way too.
PT 8 on W7 glitches! | verticleman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-03-2011 08:52 AM |
PT 8 glitches | verticleman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-01-2011 11:32 AM |
SOLVED>>Need HELP, SUPER ASAP.< |
audioindo | Pro Tools TDM Systems (Mac) | 18 | 04-21-2007 05:43 AM |
PT 6.1.1 glitches | morganpage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-17-2003 01:29 PM |
CD Glitches | mpwhite | Digidesign Hardware & Software | 0 | 08-02-2001 07:38 PM |
