PT crash after bounce
Hi DUC
It's been a while... Did a clean install to OS 10.13.6 and installed PT Ultimate 2019.6.0. Now, often PT crashes after a bounce. The bounce is done correctly though. Also I get the spinning wheel every once in a while and I seem to register that the app is more sensetive to other apps running in the background. Any ideas? Boe |
Re: PT crash after bounce
My first guess would be a plugin issue - you might try some test bounces with all instances of a particular plugin deactivated to see if it still crashes after bouncing. Of course, if it happens with no plugins in the session then it's probably something else causing it.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Ok, will try that, thanks.
12.8.1 crash during bounce | jchan | Pro Tools 12 | 29 | 10-16-2017 04:02 PM |
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct | Skwaidu | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2015 03:55 PM |
Crash at Bounce | mickeyrouse | Windows | 1 | 12-05-2014 12:54 PM |
Bounce to Mp3 crash | j.thomas | Pro Tools 10 | 1 | 11-14-2011 08:49 AM |
10.5.7 Crash On Bounce | andyj4308 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-28-2009 12:33 PM |
