003 and Firewire buss.. the real deal
Thinking about getting the 003 rack as a second LE system. I want to use my FW800 drives, but I've been told that by using the FW400 port to connect the 003, all FW drives will then run at 400 speed regardless of whether they're connected as 400 or 800. Is this really true? Are the 400 and 800 ports still on the same buss?
Ideally, I'd connect the 400 port to the 003, and then the 800 port directly to my drive(s)
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: 003 and Firewire buss.. the real deal
Which computer are you talking about? If the G5, then get a FW800 PCIe card to connect your HDss If the MBP (and it has it) use a FW800 Express card to connect the drives.. This is the best overall solution because you are actually adding new FW busses and increasing FW bandwidth.. OWC carries both items..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
It would be for the MBP, which does have the Express slot.
Came across this in a review of the Sonnet card....are they all like this? 2-Port FireWire-800 ExpressCard/34 is a wonderful solution, except for one thing that they do not mention... You can only connect self-powered drives through it. So my portable G-drives do not work through the ExpressCard, since they need power from the computer to run." Had to throw this in as well because.....seriously! Since the new 17" MacBook Pro only has ONE FW outlet (come on Apple, what happened here??), I had to get some extra ports... Another reason I love my last gen MBP
Yes, Other than the Mac Pro, all other Macs now only have only one or zero FW800 port and no FW400 port. Even the ExpressCard slot is only available on the 17 MBP. Apple is turning their "Pro" calibur machines into "Consumer Electroinics" devices.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Definately this is the truth. If you want something very good, pay more, if you want something serious, pay, pay pay even more, and even than, they won't give you everything.
my blog:Tamas Dragon |
True, and even consumers need FW yes?, but what about the issue of these cards not being able to use self powered drives? I do run in to situations where someone gives me a buss powered FW 800 drive, and it sure would be nice to run it at 800 speed.
Obsidian Dragon
Doh! Why didn't I think of that? Thanks!!
Or you get two ExpressCards (my solution), one FW800 and one FW400 so I'm covered all the time.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
http://www.mhsecure.com/technotes/Te...10/TN_0010.php In essence, if you have all your FW 800 devices at the beginning of the chain, followed by the FW 400 devices, the 400s will run at 400 speed without slowing down the 800s.
------------------------------------------------ Colin Mansfield Bandcamp Soundcloud |
The real deal- quad vs 2.7 dp... | joshua d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-31-2006 10:37 AM |
the "Real Deal" drum samples | vocalize | Pro Tools TDM Systems (Mac) | 5 | 01-10-2006 07:11 PM |
What is the real deal on Sample Tank 2? | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2004 10:37 PM |
The real deal with interleaving ram | soundboy35 | Pro Tools TDM Systems (Mac) | 16 | 12-09-2002 01:38 PM |
So tell me please, What's the real deal on Processing? | M2E | Pro Tools TDM Systems (Mac) | 2 | 09-09-2001 10:39 PM |
