c/24 and 192 io calibration
hi,the sound come truth c/24 (mic or instrument)i increase the trim until led clip indicator in c/24 began to flashing(it must be distorted or near the 0db),now send to 192io (via +4 db input or -10db input)and record to audio trac in pt,wave is so thin and also 192io meter show around-6or LOWER!!it means that i cant record any sound in around 0db and all the recorded wave are very thin.in this case i miss my 120db dynamic range of 192io.is there any body knwo about it?
nobody can run pt hd pcie in pc like me!!!hahaha... |
Re: c/24 and 192 io calibration
Hi
i have the same problem on my setup (c24 and 192). I have tried to connect a RME OctamicD on analog input and at the same time on ADAT input, with 1K tone i have 15 db of difference on digital connection vs analog. why improve the microphone signal to line level and then missing 15db to analog input??? Help??? |
Losing one side of a balanced line will give the results you are describing. Check your cables(between the C24 and the I/O box) to make sure they are wired to the correct spec(for the DB25 connectors) and verify that you are getting both signal wires(pin 2 hot AND pin 3 cold).
Calibration how to? | Terry Wetzel | General Discussion | 8 | 08-03-2015 04:02 PM |
c/24 and 192 io calibration | raga2000 | Pro Tools TDM Systems (Win) | 0 | 07-24-2007 03:00 PM |
What are you using for Calibration?? | SHIRK | Pro Tools TDM Systems (Mac) | 4 | 02-23-2003 12:26 AM |
calibration | joestudio | ICON & C|24 | 0 | 04-27-2002 07:32 PM |
Calibration | JLEpperson | Pro Tools TDM Systems (Mac) | 3 | 08-08-2001 10:07 AM |
