Old 08-17-2011, 03:02 PM
Judson Judson is offline
Default Process for revising a mix when given a new replacement OMF?
Hello,
Could anyone share their process when they are asked to revise a completed mix only because of picture changes to the visual which then creates the need to get a new replacement OMF for the audio? make sense? What's the most streamlined way to do this? Are there tools that help with this process?
Thanks for any insight!
Old 08-17-2011, 03:12 PM
kittonian kittonian is offline
Default Re: Process for revising a mix when given a new replacement OMF?
Create a new session with the new OMF and then either import your session data from the mix you've already done OR go back to your mix and import only the new changes you need to work with from the new OMF session.
Good luck!
Joshua Aaron
President/Chief Eng.
AudioLot/AudioLot Studios
Pro Audio Sales/Consulting
http://www.audiolot.com
Follow AudioLot on Facebook
Old 08-17-2011, 03:14 PM
Thanks for the help!
PT will not process Effects ? djdeo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-07-2011 12:02 PM
Problem populating HD 4 accel + Process + Process Brandonx1 Post - Surround - Video 6 07-15-2010 04:40 PM
Uninstall Process Mount Royal Pro Tools TDM Systems (Mac) 1 06-26-2009 10:47 AM
hd process and accel process in same machine? blumediaprojekt Pro Tools TDM Systems (Mac) 1 02-01-2006 07:51 PM
Next Process after mix? DaMixG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2005 07:51 AM
