Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 01-11-2014, 09:24 AM
jobey jobey is offline
Default PT11, MacBook Pro and Focusrite Forte latency issue
I bought recently the Focusrite Forte for my MBP. I hadn't gotten PT yet, so I was playing with it in Garageband for fun and got no latency issues whatsoever.
Now that I have PT11, I'm running into all sorts of problems. There's terrible latency, and what audio is captured is very broken.
Changing the HW buffer size hasn't resolved anything, toggling dynamic plug-in processing doesn't affect it, and both delay compensation and low latency monitoring does nothing. I'm also doing everything on an external Seagate hard drive at 7200 rpm.
Any suggestions on next steps?
My computer is:
Mid 2010 MacBook Pro 13"
2.66GHz Intel Core 2 Duo
4GB RAM
OS X 10.9.1
Old 01-13-2014, 05:04 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: PT11, MacBook Pro and Focusrite Forte latency issue
Have you gone through the Optimization Guide? Also, 10.9.1 is not supported yet with Pro Tools (I'm not sure that is the problem)
Please Note
Mac OS X 10.9.1 Mavericks is NOT approved at this time and should not be used until Avid announces support for it.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 01-13-2014, 08:05 AM
junkgear's Avatar
junkgear junkgear is offline
How do you have your session set up in PT (sample rate, bit depth) compared to GB?
Are you using the same external drive when recording to GB?
Will K
System Details
Old 01-14-2014, 01:42 PM
I have resolved the issue:
I was running Pro Tools 11.0.0 from Guitar Center when I should've really also downloaded 11.1.1. to help resolve some of the Maverick compatibility issues. This definitely helped some.
It appeared the issue was a Focusrite driver, but it wasn't available through their main website which is why I had no idea at first. Once I got that driver (plus a few others for the software control panel for the Forte), I restarted my computer and loaded into Pro Tools just fine. I now have crystal clear audio and only experience latency when my HW buffer is set to larger then 256.
The website which started me on this path is here:
http://www.sweetwater.com/sweetcare/...0-9-mavericks/
I used both the class compliant mode application as well as the updated Forte 1.2b2 driver. Other Focusrite Forte users should make sure their Forte suite drivers are up to date as well (viewable to the right of that same page).
To anyone else stuck, try the above and restart your computer between steps often. Hope this helps someone! Thank you both junkgear and joelg, I appreciate your suggestions!
PT11.0.2 full ed. + Focusrite Scarlett 2i4 issue Roland Shaak Windows 3 08-20-2014 10:57 AM
Focusrite Forte v1.0.1 derF Pro Tools TDM Systems (Mac) 2 04-28-2007 03:40 PM
Focusrite Forte tarfungo Pro Tools TDM Systems (Mac) 1 07-25-2006 05:06 AM
Focusrite Forte? mozart Pro Tools TDM Systems (Mac) 4 06-09-2005 03:13 PM
focusrite forte is really something 70bit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-03-2004 06:10 AM
