Old 01-28-2009, 02:38 PM
Maddawg383 Maddawg383 is offline
Default How do i adjust gain on 003+
All my mic input levels are clipping badly and all my gain controls are all the way down 0.
What setting to i have incorrect?
Old 01-28-2009, 02:44 PM
andydunham andydunham is offline
Default Re: How do i adjust gain on 003+
Just by looking at the picture it looks like you may have the +48 button on? Select which channel you want to use at the bottom, and then if the +48 button is lit, unselect it and see if that solves the problem. I'm not too familiar with the 003+ but just my 2 cents.
Old 01-28-2009, 03:08 PM
Oops , i thought that was for phantom power.
But even my dynamic mics are clipping and the +48 is not on on those channels.
Old 01-28-2009, 03:58 PM
The +48 is for phantom power, I just thought maybe you had accidently tapped it and it was on. If you've checked that and it's not the problem, make sure that the mic line/DI switch is in the correct position. Other than that, I'm not sure what else could be causing your problem. I'll keep looking into it. Anyone else?
Old 01-28-2009, 04:19 PM
They are in the mic position for mic's
And my 48v button is on for my condensors only.
Old 01-28-2009, 04:45 PM
flommer flommer is offline
Did you try the pad?
Do you have anything else to compare it to, like an outboard mixer or something with meters... Are the mics just too close or the guitars too loud?
Seems strange that the dynamic mics would have problems..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-28-2009, 05:01 PM
The pads do help a little.
I'm micing drums.
All the gain knobs are at 0.
Am i still supposed to get a heavy signal when all the gain knobs are turned down all the way?
My mackie 1604 vlz pro is fine with the mics where they are.
Old 01-28-2009, 06:46 PM
One other question... Do you have Options>Pre-fader Metering enabled?
Old 01-28-2009, 07:09 PM
if thats what the default setting for 7.4 is, then yes.
But i will have to check.
Gimme some time to boot up my system and check.
Old 01-28-2009, 07:37 PM
it made no differance.
The signals are still hot as hell either way.
adjust clip gain with dcommand zakco ICON & C|24 0 06-25-2013 06:27 PM
Can I adjust gain on just one track in? oldgitguy Eleven Rack 3 06-24-2013 03:21 PM
Adjust input gain of Guitar in (ASIO) ThunderKyss Eleven Rack 9 04-16-2013 05:16 AM
How to adjust gain on 003R inputs 5-8 Matt Rushmore Pro Tools 9 15 05-04-2011 10:01 PM
Output gain adjust? stainless Pro Tools M-Powered (Mac) 1 04-17-2006 09:43 AM
