Mix core w/ 2 DSP Farm PT 6.4.1
Hello all ...
Our system is Mix core and one DSP Farm PT 6.4.1 and Mac G4 933. The engineer needs to use more TDM plug ins. If we add another DSP farm ( currently on the the shelf needing upgrade ) how many more TDM plug ins will this allow us to run ? If we do go ahead and add this card we'll also have to add a MAGMA PCI expansion chassis and move our DIGI cards Miro and ATTO cards around to make room ( aarrg what a nightmare ) . Please advise. Thanks Joel
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2 |
Re: Mix core w/ 2 DSP Farm PT 6.4.1
depends on the plugins and the farm card. Mix farms have more chips. This should be all covered in the manuals. It's fairly complicated. You can put something like 15-20 channel strips on a single DSP and only one Reverb 1 so as I said it really depends.
A rough guide would be that each chip on a DSP Farm would allow you to use one more power-hungry plug-in in a “worst case scenario” situation (i.e. using the most demanding plug-ins).
There are four chips on a Farm card. Hungry plugs include most reverbs, Autotune, Amp Farm, some finalizers etc. Many other plugs use less than an entire chip, so you could run more. Hope this helps. BF |
Mix Core, DSP Farm QE, 6.4.1 TdM on 10.3.4 - Farm not shown | Table Syrup Records | Pro Tools TDM Systems (Mac) | 2 | 06-18-2008 08:00 PM |
Mix Farm WITHOUT Mix Core? | SiliconAudioLabs | Pro Tools TDM Systems (Mac) | 3 | 04-21-2005 10:35 PM |
mix core and dsp farm | kiddyid | General Discussion | 4 | 10-29-2002 12:09 AM |
D24/DSP farm v. Mix core | poppy | Pro Tools TDM Systems (Mac) | 4 | 05-20-2002 12:36 AM |
MIX Core, MIX Farm, DSP Farm & G4 933MHz | Chief Technician | Pro Tools TDM Systems (Mac) | 6 | 04-25-2002 06:59 AM |
