Is an Aggregate possible when running M powered PT
Hi
If I own a firewire 410 and a Fireface 800 (which I do)...can I make an aggregate audio device and run Protools M-Powered? I obviously need the firewire 410 to run M-powered...but Id like to use the quality ins and outs of the Fireface... Thanks Royalston |
Re: Is an Aggregate possible when running M powered PT
No, ProTools uses a proprietary driver, not CoreAudio.
that sucks
if you used the beta (released a long time ago) the PC guys
were able to get a few PCI cards to read as one. Unfortunately that does not help your situation.. (nor did it work for macs) if you want to use the retail release, then you will be using 1 interface.
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
Hello. If you look around the forum you will see that some people have had success running more than one Delta 1010 card in their system. So at least two of the same card is possible. I forget if it is the M Powered Windows or Mac forum but the thread is around here somewhere.
froyo |
PT LE 9.0.5 (under Lion) is not running with Aggregate I/O | Franco1967 | macOS | 5 | 08-22-2011 11:24 AM |
Running 002 vs NOT Using R002 w-Aggregate | wdjudd | macOS | 1 | 04-13-2011 12:45 PM |
Aggregate device trouble Snow Lep! Tascam US122 won't aggregate? | crizdee | Pro Tools 9 | 3 | 12-02-2010 03:17 PM |
Running LE & M-Powered on the same mac | jaman4fun | Pro Tools M-Powered (Mac) | 2 | 03-15-2010 08:48 AM |
Digi 002 running on M-powered? | scottprotools | Pro Tools M-Powered (Win) | 3 | 02-03-2010 11:55 AM |
