11R S/PDIF not being seen by Focusrite Scarlett 18i20
first time using S/PDIF.
I have 11R S/PDIF output hooked up to the Scarlett 18i20 (3rd Gen) S/PDIF input, but in I/O settings, the only digital channels that show are the 8 ADAT channels. Do I need to have both S/PDIF input and outputs connected for this to work? happy to order another cable, but wondering what I'm doing wrong. Currently have it connected via analog outs, but would rather avoid the extra conversion steps... thanks.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
Re: 11R S/PDIF not being seen by Focusrite Scarlett 18i20
Hey, I have both an 18i20 and Eleven Rack - usually just use an amp sim when recording though.
When you're in Scarlett MixControl, you can click on any of the input headers (above the faders) and change it to whatever input you want, ie. S/PDIF. Down below you can also send any of the inputs to any output. These types of interface mixers are very powerful, but hard to get a handle on - I've struggled by times. Sweetwater has a bunch of videos that are quite helpful, just search their chanel for Focusrite Mix Control. I think this video in particular is what would help: https://www.youtube.com/watch?v=AV6u7w15bq4 Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Pro Tools Setup>IO pages are *not* where to look to get started. They often do not reflect reality. You need to open up the user guides for the Eleven Rack and 18i20/Focusrite Control and systemically follow the setup there for both boxes. Start at the Eleven Rack and and work towards the 18i20 and then Pro Tools. Setup the Eleven Rack Digital Out to what you want. Ideally confirm it's working--if you have say a headphone DAC to test with--or use the Focusrite mix (see comment below). Make sure you are setting the clock rate in the Eleven Rack to what is expected in the Scarlett/your session. Then you need to think about about signal routing in the 18i20, read the Focusrite Control documentation for that. Actually ideally you learn Focusrite Control enough and can quickly setup a mix from S/PDIF in on that to main outputs, all stand alone from Pro Tools. So you can check the S/PDIF In from the Eleven Rack is working. I'd think that's a great thing to aim for if you are not comfortable with Focusrite Control yet. And finally in Pro Tools you can try defaulting the Setup>IO pages or manually editing the IO paths to label whatever is the S/PDIF input. But they are just labels for you, and sometimes may not label correctly, even if everything else is setup correctly OK. If in doubt you should be looking at what the numeric output I/O are on the Focusrite and make sure you are using numeric IO in Pro Tools. Now worry about clocking setup (in case you get clicking etc.). |
hi
bumped into something similar when using 11r spdif output. searched in manual. 11r manual: "Pro Tools must also be set to clock from the digital device, or no audio can pass be- tween them." "If you get no signal or a compromised signal, double-check that Pro Tools and your exter- nal device are set to the same sample rate and digital I/O format, and that Pro Tools is set to receive sync from the external device." seems the 11r s/pdif input has to have a signal connected, clocking the entire system |
Your quote from the manual, has nothing to do with the leap you are making above. Quote:
/FZZ |
What do you mean "show up". Do you just mean a "s/pdif" label it's not listed in Setup>IO>Input? Again, that is not important and the label can easily be wrong. You need to be very specific. You can "hear the Eleven Rack".. where exactly? Going through the mix in your 18i20 monitor? Or directly from the Eleven Rack connected to analog monitors? If you did confirm you have S/PDIF coming into the 18i20 by monitoring it in the Control mixer.. then *ignore* what the Setup>IO>Input labels show and test if you have an input on the expected IO input number given by the 18i20/Control documentation. |
And for hard core reamping, my suggestion would be to use the equivalent plugins in Pro Tools. Once you get used to it it's much easier, and gives more flexibility. Anyhow lets not clobber this thread about other stuff. |
Umm, I did start this as a separate thread, so not sure what you mean.
when I say I can hear through the SPDIF, If I choose SPDIF as the input to the Main out or headphone out vs. DAW Mix, I hear the SPDIF out. But I don't see any option in input to select SPDIF. I'll submit a ticket to Focusrite but believe they'll just say it's a pro tools issue, not us.
PT 12.5 Focusrite scarlett 18i20 Issue | Blackers | Pro Tools 12 | 1 | 06-25-2018 03:20 AM |
Focusrite Scarlett 18i20 question | vandilization | Third Party Interfaces | 5 | 12-23-2017 11:08 AM |
Focusrite Scarlett 18i20 distorting sound with PT | Jacob Champoux | Pro Tools 12 | 5 | 06-07-2017 07:50 PM |
Focusrite scarlett 18i20 | madselhoff | Third Party Interfaces | 6 | 01-25-2016 04:45 AM |
Pro Tools 11 with Focusrite Scarlett 18i20? | hermonmusic | Third Party Interfaces | 24 | 06-27-2015 08:53 AM |
