Sustain Pedal Issue with Protools and studio logic SL88
I have "2" Studio Logic SL88 working independently as my controller for my instruments in Protools on 2 separate computers. In both independent setups with protools, When I record an instrument on protools, it sounds like it is recording correctly, but when I playback, I do not hear the sustain that I recorded the instrument. It sounds staccato, on both setups.
On both pianos: I have the recommended studio logic pedal: VFP 1/10. It is connected to pedal port 1. The settings for the pedal 1, in the piano, is set to Damper. I have tried other settings for the pedal, but it does not change anything. One of theses computers is the latest Mac mini model on one of the setups. My protools version is 2018.3.0 Please help me get to start recording the proper recording on Protools. I can't get started to record anything with this problem. THANK YOU SO MUCH FOR THE HELP. GREATLY APPRECIATED> |
Re: Sustain Pedal Issue with Protools and studio logic SL88
Hi, welcome to the community.
You are probably experiencing MIDI Merge Bug there. Search for it, a lot of threads in the past
Just out of curiosity, do you have the pedal pressed before you click the transport to record or have the pedal pressed during a count off?
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
thank you for asking, but no
In no particular order:
Your version of PT is not considered compatible with Mojave according to the compatibility chart. The last 'compatible' OSX would be High Sierra. Get the free MIDI utility called snoize. Run it with PT shutdown and it will show you what the pedal is doing. I find the utility indispensible when trying to sort out MIDI issues. And for our Windows brethren there's MIDI-OX. If it shows the computer is receiving cc64 check the MIDI event list in PT and if it isn't see the next bit below. Make sure that PT isn't filtering out the cc64 (that's sustain cc) message coming from your keyboards. |
The problem is on your keyboard. You must disable all the zones but one. The display on the keyboard should show only one of the four zones, the other 3 can be disabled via the controllers on the keyboard. This is all you have to do.
Issue with mini grand and sustain pedal | greenpasta | Virtual Instruments | 2 | 03-15-2018 12:08 AM |
Protools 11 Midi Sustain Issue | joshlmiller | Pro Tools 11 | 4 | 06-10-2017 03:36 AM |
mini grand & sustain pedal issue | cplaza | Virtual Instruments | 6 | 09-27-2014 09:15 AM |
Make my sustain pedal a kick pedal | dr beef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-11-2005 12:20 AM |
Make my sustain pedal a kick pedal | dr beef | MIDI | 0 | 05-08-2005 10:14 PM |
