Re: Control 24 completely dead - fuse blown?
Incidentally we have now put a APC Smart UPS between the mains and the C|24.
Our Control 24 blew after a mains outage
[B]Pro Tools 2018.4, C|24, X32 Rack, Win 10, Waves 10, Komplete 11, composers collection |
In case someone comes across the same switching power supply failure that I experienced recently after a main AC problem, here's a possible solution.
I removed the blown T5A fuse soldered on the circuit board and from there ran two wires to a standard fuse holder on the back of the PSU rear pannel, which implied drilling through two sheets of metal near the on-off switch. When I turned the board back on, the new fuse blew instantly. Then I found a hint about checking the PSU FET transistor, which turned out to be kinda loosely bolted onto its radiator, meaning it had probably heated up badly and making it more likely to die when stressed. I replaced it (8€) and the board came back to life ! The specs at RadioSpare are SPW20N60S5, Canal-N, 20A, 600V, A-247. And I strongly suggest to working Control 24 owners to open the PSU pannel and crank the **** out of all the bolts holding heating componants to their radiators... |
+44 (0) 1189-820 911 [email protected] |
Blown Fuse Digi 002 Power supply | liamMo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-08-2013 08:51 AM |
Faders are DEAD! Completely lifeless... | mtung | ICON & C|24 | 9 | 03-06-2006 08:43 AM |
BLOWN FUSE!!!!!!! | Rtpas11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-02-2006 04:45 PM |
Help! Dead 192! Where is the fuse???? | steins | Pro Tools TDM Systems (Mac) | 0 | 06-02-2005 09:06 AM |
Brand new Digi002 once working fine, now completely dead | steve mcconnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-28-2003 06:50 PM |
