Structure - transposing pitch globally
Another noob Structure question here.
I have several samples (one on each key) of sound effects. I'm looking to slow the entire set down, say 5 semitones. I've gone into Patch & also Part Transposition and tried changing the pitch, but what I get instead is a change of triggers. The same key pressed will play a different sample but still at original pitch. What I'm looking for is to press a key, have the same sample play as before, but pitched down by my specified amount. Ideally this would be assigned to a MIDI controller for automating. Using the Pitch wheel does what I want, to a degree, but the pitch wheel springs back to 0, and I'm looking for a solution that does not do that. Also - this needs to be something that can be patch independent, so if I have more than one patch loaded at once the pitching I'm doing in this patch doesn't affect another. Thanks for any help! |
Re: Structure - transposing pitch globally
Pitch in the zone editor seems to work but I'm not finding how to assign that to a controller. <Control Clicking> doesn't do anything.
Still looking..... |
What about using key switching and transposing the root keys in the editor?
I'll have to figure out how to do that. I'm such a noob. ☺ Thanks for the input!
transposing structure parts without actually transposing them | djcalg | Virtual Instruments | 0 | 07-13-2010 09:06 AM |
transposing and elastic pitch | zamunster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-23-2010 06:53 PM |
transposing and elastic pitch | zamunster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-23-2010 01:54 PM |
Structure Pitch Bend issue. | filosofem | Virtual Instruments | 1 | 07-31-2007 09:45 PM |
Pitch transposing a bass audio file | Imagine | Pro Tools TDM Systems (Mac) | 3 | 02-26-2005 01:35 AM |
