Re: Acoustic Guitar Tones
I have a question to piggy-back into this discussion:
I have a Boss AC-2. Is that designed to be a "stomp box" that sits in the signal path and run into an amp model or is it designed to be run on a stand alone signal path into a DI? Right now I run a Boss LS-2 that sends one side to the 11R and the other side to a BBE Sonic Stomp -> Boss AC-2 -> LR Baggs Para Acoustic DI. Is this the correct way to implement the AC-2 or should it be inline with the rest of my pedals in the FX Loop of the 11R and run into an amp model? If it's the latter - that it should be used as a stomp box into an amp model, does anyone have a good amp model to use with the AC-2? Should the cab model be on or off? Any other strategies to try? ... sorry to hijack this thread a bit, but it's relevant to the OP. |
What's the manual say? Not trying to be rude, but it might give a hint on where to use it as far as in conjuction with the 11R. Is it a guitar simulator or an acoustic processor or both (which i think it is).
If both, my initial thought would be to do opposite of with what dawnsman told me. kill the preamp, go guitar -> 11R -> (in pedal chain in now) bypass preamp -> a bit of chorus/delay/reverb (your choice) -> out. Would the AC-2 go before or after the chs/dly/rvb? I'm thinking before. To cab or not to cab is remaining question. I guess if there was some sort of FRFR cab in the 11R. I've not dug deep enough to determine. |
There are also numerous requests on ideascale for an acoustic amp to be included in a future update, Vote here; http://protools.ideascale.com/a/idea...ussionID=11273
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
So - last night I had a bit of time to experiment. I ran the AC-2 inline with the rest of my stomp boxes in the FX Loop of the 11R. I chose three different clean patches I have, bypassed the cab/mic in each, placed the FX Loop before the amp, and did some tweaking. Two of the patches sound "ok" but the third came out pretty good using the neck pickup of my Strat. I'll test that Sunday morning at church to get the final verdict on it. However, I did learn some more. The AC-2 has two outs - "Output" and "EG Out". If both outs are used the EG Out is active when the pedal is "off" and is designed to route to the rest of your electric guitar signal chain. The OUTPUT is active when the pedal is "on" and can then route to a DI then to the board. If my above patch turns out to be a loser on the church PA then I'll go with this as my Plan B. |
Acoustic w/peizo > 11rack > BLueline Bass amp everything at 12oclock no bright w/no cab > little comp little verb = good to go
#17
^ and also a flat response is not a great setting for a piezo equipped acoustic..
Acoustic Test Tones, Pro Tools Session | Mikbunn | Tips & Tricks | 1 | 03-29-2008 11:28 PM |
Acoustic Test Tones, Pro Tools Session | Mikbunn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-06-2008 07:39 PM |
Digizines' guitar tones test!!!!! | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-04-2004 04:42 PM |
s/pdif getting different guitar tones!! | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-08-2002 05:37 PM |
Vox & acoustic guitar together | crowdog | Tips & Tricks | 5 | 11-06-2000 02:44 PM |
