Old 07-06-2015, 11:54 PM
brutalzacjames brutalzacjames is offline
Default Eleven Rack no input
This morning i was able to use my eleven rack perfectly. I then installed the standalone plug in to use it in protools to do some re-amping, followed all the guidelines and did it correctly.
However no my hardware unit does has no input. I have hardware reset it, made sure the input is guitar and not re-amp but i get nothing. I plug my guitar in and there is no signal going in. Nothing in the on board tuner, no sounds, nothing. I have reset it twice now, updated firmware etc...
Help please it's driving me crazy!
Old 07-07-2015, 12:08 AM
Default Re: Eleven Rack no input
Most common cause of this type of behavior is you have the rig input to the Eleven Rack set to something other than Guitar Input.... which is very common when folks set the Eleven Rack Rack Input to reamp and then forget to set it back.
But you are talkign about a plugin? There is no "standalone plugin", you mean the stand alone editor?
... so you are reamping through the Eleven Rack and for got to put the rig input back to guitar in from Reamp input.
Old 07-07-2015, 07:59 AM
Benoni's Avatar
Benoni Benoni is offline
Not sure if I understand what you are asking about? Are you trying to play your guitar through the Eleven Rack and into Pro Tools? Or Re-amping?
Things to check in Pro Tools would be your I/O, try defaulting it.
Pro Tools - Default the I/O Video
https://www.youtube.com/watch?v=rxZ9SgQm8H4
As Darryl says, one of the main points of confusion is having the Rig Input set wrong
Eleven Rack - No Guitar Sound? Check RIG INPUT (Troubleshooting)
https://www.youtube.com/watch?v=ccPnvrsO5I0
And if you are Re-Amping, here is a step by step video
Eleven Rack - Re-Amp in Pro Tools
https://www.youtube.com/watch?v=ICzu75EZjkQ
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Record through Eleven Rack Mic input? microstudio Eleven Rack 10 08-22-2013 06:46 PM
Intermittent Eleven Rack input Bridgepin Eleven Rack 7 04-24-2011 04:54 PM
Eleven Rack not showing as input mac PT9? microstudio Eleven Rack 6 03-15-2011 09:15 PM
PLEASE HELP Eleven rack no input signal voma79 Eleven Rack 5 03-02-2011 09:14 AM
Eleven Rack..True Z input, PMcC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-28-2010 08:56 PM
