Can someone please explain this plugin window .. ?
Hey all,
I just watched this YouTube video off Russ from PTE explaining the UAD Fairchild plugins, and I noticed his plugin windows don’t have any options/menus etc .. at the top of the window. It kinda looks like he’s using the PRE’s within PT - but tbh I’m 100% unsure at what’s happening in his session. Has anyone else seen this, or knows what’s up .. ? https://youtu.be/VvaMn1XpLeM
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Re: Can someone please explain this plugin window .. ?
Russ doesn't exactly explain how he's running the Fairchild's in but if you look at the inserts in PT you see a bunch of Blue Cat Patchwork instances. If you go further on in the video at around 13 minutes or so you'll see that when he talks about taking the plugin in and out you see the Patchworks instances go from enabled to disabled (or bypassed). That's what leads me to think he's running inside Patchworks. And Patchworks doesn't show plugin menus like for presets, etc.
Why he's running inside Patchworks I have no idea. |
He does a lot of reviews and has multiple DAWs running. Likely he installed the VST versions of the software and didn't get around to installing the AAX versions. You would need the Blue Cat Patchwork to make the VSTs run in PT.
That's possible but highly unlikely. I say that because most people would let an installer do it's thing and install all plugin formats at one time. The extra disk space used is minimal.
Not so unlikely if he came to Protools after he installed the plugins in another DAW. He might find it easier just to use that which is already installed. But I agree it's easy to install the AAX versions.
What I'm trying to get at is that neither Russ nor most other people would just install the one plugin format. As you said he works in multiple daws and it only makes sense to install every format. PT is Russ's primary daw or at least it was at one point.
maybe he has chains set up and saved in BlueCat for parallel and series. this isn't possible with aax versions. also bluecat hosting offers a wet/dry mix on plugins that don't natively have one which is nice.
The video edging towards 5 years old? Have UAD updated their GUI since then? The timing also puts the video after the release of Pro Tools 11... but before UAD actually even supported AAX64.
He is probably just doing what a lot of people did then, and is using workarounds to get everything up and running.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Can anyone explain the System Usage Window? | Dizzi45Z | Pro Tools 11 | 29 | 12-06-2013 09:35 PM |
Plugin separating from Plugin Window | listnersupported | Pro Tools HDX & HD Native Systems (Mac) | 0 | 06-15-2012 01:29 PM |
Can someone explain.....auto read..mix window... Pro Tools | tomyco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-10-2008 06:06 AM |
Can I see more than one plugin window at once? (OS9, PT5.0) | apetrocelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-11-2003 11:33 AM |
Explain I/O setup window to me please.... | MarkGenero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-01-2001 10:22 AM |
