Old 04-10-2019, 07:49 AM
karegranat karegranat is offline
Default User defined insert slot for EQ/DYN only works on the DAW, not on surface?
I have a problem with the preference that defines the slot PT looks first for EQ or DYN plugs when a channel is attentioned. The workstation opens the plugin in the right slot, but the S6 surface does not. So, for instance, if I define my main EQ to be in slot D, the S6 surface attentions the first available EQ plug counting from the top slot A, but PT itself opens the plug in slot D.
Am I missing something here, or is this a known bug?
PT 2018.10
Latest Eucon software
OSX 10.12.5
Regards,
Javed Kurd
Oslo, NORWAY
Old 04-10-2019, 08:04 AM
innenhofstudios innenhofstudios is offline
Default Re: User defined insert slot for EQ/DYN only works on the DAW, not on surface?
yes, on MTM it seems only to be intended to just fill the slots up one by one...on Display Module it is like it is on DAW...
www.innenhofstudios.at
Old 04-10-2019, 08:09 AM
So, a bug then?
The preference panel refers clearly to EUCON surfaces and cycling start, and that is exactly what DOESNT happen...
J.
Old 04-11-2019, 10:00 AM
EddieJones's Avatar
What versions of S6 and PT are you on..this should/does work
Old 04-11-2019, 10:05 AM
Hi Eddie!
The versions are:
PT 2018.10
S6 18.3
Mac osx 10.12.5
Thanks!
Javed.
Old 04-11-2019, 11:07 AM
EddieJones's Avatar
OK, sorry, I now realize what you are asking. The cycling pref is just for that at the moment and only works on the channel strips. If you attention a strip and cycle the EQ from that strip you will see the MTM change to the correct EQ. We need to add a way to cycle from the MTM yet.
Old 04-11-2019, 12:13 PM
So, if I understand you correctly: When I set my PT preference to be:
EUCON Surfaces EQ DYN cycling starting at Insert: d
Does that mean that when I press the EQ button on an S6 channel, the DAW opens the EQ plugin in slot d (if present), but the console does NOT attention the same EQ plugin to the knob module, but attentions the first available EQ plugin counting from Insert a and downwards?
If so, is this the intended behaviour? Should´nt the S6 attention the same plugin as the DAW? It doesn't make sense to me...
J.
Old 04-11-2019, 01:10 PM
EddieJones's Avatar
No it should show the same EQ (slot4) on the strip and MTM EQ block. You just can't cycle from the MTM.
Old 04-11-2019, 01:11 PM
Ok. Good to know. Only, the strip shows the first eq instead....
Old 04-11-2019, 01:14 PM
EddieJones's Avatar
Its actually technically impossibe to have 1 track show 2 different EQ's. There is only 1 pipe. Are you confusing the EQ knobset with Inserts ?
User-defined keyboard shortcuts wevets Windows 12 08-16-2018 06:41 PM
User defined layer on Profile.. Audioartist VENUE Live Sound Systems 0 06-04-2018 06:22 AM
Move/copy multiple plug-ins to other insert slot at once pericoloso Pro Tools 11 14 07-11-2014 08:48 AM
PT 8.0.3 Snow Cat - Pre Release | 1 Second Time Lag when clicking Insert Slot 25ghosts Pro Tools TDM Systems (Mac) 6 10-30-2009 01:34 PM
6.7cs7/OSX10.3.7No user defined Keyboard shortcuts hanz marathon Pro Tools TDM Systems (Mac) 7 01-23-2005 02:53 AM
