Muting tracks with no reason
Hi! This has been happening once in a while recently.
It is a 5.1.1 TDM Mix session. I am playing back so as to record stereo mix from 02R outs ( AES or lite pipe) into a spare stereo empty track at the very same session. Sometimes one track mutes. So I select stop, play and it playb back normally. The sessions sometimes is small, let us say with only 9 tracks. Generally I handle much bigger sessions without that happening. Yes, voices are in auto mode, 512MB RAM on a G4 800QS, no fragmentation. Sometimes I am using on the bass track the following inserts: VW > CB2> Q6 >. VW is RTAS, the other two are TDM. Buffer size is at level 2, utilizing OS 9.2, Mix system ( d24 + dsp farm v2 + mix farm). Will I need to change CPU usage and so? Thanks for any info [img]images/icons/smile.gif[/img] [img]images/icons/tongue.gif[/img]
Alécio Costa Studio High-End e-Mastering & Music Production www.aleciocosta.com http://www.facebook.com/alecio.costa PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter. |
Re: Muting tracks with no reason
Alecio -
Are you absolutely certain there are no automation breakpoints on the tracks that are muting? 1st thing I would check; they will show up if you make the session start time earlier or if you import tracks from another session. JW |
John, I do not use any automation inside PT. Everything is automated on the console, except for occasional plug-in parameters.
Also, I repass the same part and it plays fine.
Hi Alecio, so by "mute", do you mean the Pro Tools mute light comes on, or does the audio disappear because of a mute somewhere else? Unless it's the latter, I'd go with John's suggestion. Sometimes even though you don't rememeber putting a mute on, they just seem to appear on the mute automation graph.
Doug, the audio out is muted , not the track itself. Thanks.
Digi?
I've noticed this very occasionally. It usuually is one output or recently an aux input that I use for my talkback mic.. It will just disappear for no reason then pop back. It's only happened 3 o4 times in the past year.
HD2 Sys 9.2.2 g4/933 768 mg Ram
Mac Pro: 3,1, 8 core, 6GB RAM. OS 10.6.8, Protools 10.3.8 TDM HD2 Accel. |
Hi Russ. Which version are ya using? 5.3? 6.x?
Mine is 5.1.1 Digi?
Not sure if this is the same, but I have had this happen sometimes with my system (QS G4 800, Mix Core, DSP farm II, Samplecell, 5.1.3) where it seems to be caused by the DSP Farm--meaning that any tracks that have a plug in that resides on the DSP farm go silent until I remove the plugins--this doesn't happen on the Mix core, though. So you may want to check if one of your dsp cards isn't passing audio. Unfortunately I haven't really figured this one out except that it seems to be plugin related.
it is funny that even no metering happens at the problematic channel... like it was forzen for a moment, til ya hit stop and play again...
Does it ever happen on a channel with no plug-ins?
If not, can you localize it down to a specific plug-in common to the channels doing it? Losing meter either means it's not playing from the drive, which generally wouldn't result in a mute, but a DAE error of some sort, OR you've got something funky with a plug-in. See if you can figure out a pattern of commonality between the seemingly random channels muting. That may be difficult since it sounds like a pretty intermittent problem. Good luck with it. Keep us posted. |
Tracks Muting During Bounce | jeoffharris | General Discussion | 6 | 11-13-2013 08:00 AM |
Tracks Muting bug is back in PT HD 10.2.0 | mgoorevich | macOS | 8 | 07-28-2012 08:21 AM |
Solo not muting all tracks | Stickman7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-18-2009 07:06 PM |
Tracks not muting | JHJ | Pro Tools TDM Systems (Mac) | 8 | 12-16-2006 05:31 PM |
Muting tracks during bounce | phdumas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2001 07:51 AM |
