Old 09-15-2018, 03:43 PM
Rockman413 Rockman413 is offline
Default Why this recorded 32 bit audio's waveform is strange
Project is in 32 bit depth. I turn the 1st audio all the way up +36db and record into the 2nd audio track, and that "Audio 1_03-01" is the recorded 32 bit audio. I clip gain -32.9, and play it back, it does not clipping or distorted thanks to the 32 bit audio. But why the waveform, left and right is identical? Even the meter shows left and right and different and always changing like a normal stereo file.
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 09-15-2018, 04:34 PM
AlexLakis AlexLakis is offline
Default Re: Why this recorded 32 bit audio's waveform is strange
Just curious, what exactly is it you're trying to accomplish?
I don't mean just in this thread. I mean in the grand scheme of things.
Do you record your own music? Other people's music? Are you in school for this stuff?
Inquiring minds want to know.
Old 09-16-2018, 12:25 AM
BScout BScout is offline
I take it you don't understand what zoom is or threshold?
Take a piece of paper and put a dot on it. Then draw some loops around the outside of the dot.
Move the paper close enough to your eye so all you see is the center dot.
Where do you think the loops went? Did they disappear? Or are you just so zoomed in that you can't see the outer loops anymore?
Old 09-16-2018, 08:21 AM
Of course I understand the zoom. What I mentioned only applys to 32 bit audio and even it's been clipped gain - so much and the volume is low and it's still looks like a thresolded one. Open your pro tools and do an expriment so you'll be the same page with me.
Old 09-16-2018, 09:15 AM
amagras amagras is offline
I think what B meant was that the your tracks have been visually zoomed, that has nothing to do with audio, its just to help you see the representation of the audio.
Can you try explaining yourself again more clearly? We are having trouble here understanding what you are after.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Audio tracks waveform appearance strange. Help![solved] Jbiondi Pro Tools 11 4 08-10-2016 10:43 PM
Strange waveform redraw behavior after audio suite render PeterScherr Pro Tools 12 6 03-31-2016 02:06 PM
strange waveform bbbirchey Post - Surround - Video 4 05-24-2013 01:27 AM
Problem With Recorded Waveform - Some Missing ? session48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-24-2008 03:52 PM
Strange looking waveform Greg M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 08-29-2002 12:56 AM
