Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-19-2009, 12:14 PM
finkbmx finkbmx is offline
Default Original Mbox as stand alone mic preamp
Hey, just wondering if anyone knows if its possible to use the original mbox, the one with the focusrite preamps, as a stand alone mic preamp using either the analog or digital s/pdif outputs without using pro tools. This site says it can be used this way. http://www.kellyindustries.com/compu...sign_mbox.html
Obviously a power issue exists since its bus powered but could be resolved by plugging it into a usb converter similar to the ones used to charge your ipod. Let me know if anyone has tried this or knows if its possible. Thank you.
Old 01-19-2009, 09:34 PM
Default Re: Original Mbox as stand alone mic preamp
In theory, you could plug it into a powered USB hub, dial the MIX knob to DIRECT and get 2 channels going out the analog outputs.
Old 01-19-2009, 09:50 PM
audiogeekzine audiogeekzine is offline
The preamps on them aren't that great but might be a real cheap way to get 2 more preamps into a 002/003 etc. That is if you can find one real cheap.
good idea
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 01-20-2009, 02:26 PM
I tried it yesterday and doesnt seem to work i get nothing out of any of the outputs. Ill try again once i get my studio setup.
Old 01-20-2009, 06:07 PM
If you have lights on, check the MIX knob. If you have no lights, then you have a USB/power issue. You could try plugging the Mbox into your computer and then go into hardware>device manager and tell it to NOT USE the Mbox(i.e. find the Mbox in the list of hardware>double-click to open properties and tell it DO NOT USE in current configuration)
Old 02-27-2011, 10:00 PM
birddogstudios birddogstudios is offline
I got this to work by plugging my mbox 1 into a computer that was running snow leopard which isn't supported, it did not give me "usb" connectivity per the light on the front, but it did power up and I plugged in my trusty sm57, I had to set the input/playback knob to all the way 'input' and used the "line output (trs)" and it passed signal as a standalone mic pre
pretty sweet as I've heard it is the most useful doorstop ever now that avid is no longer supporting them w/ pt or as standalone units in snow leopard, now it's my focusrite mbox 1 preamp "vintage" digidesign unit
Old 11-13-2016, 04:12 AM
zolko zolko is offline
Actually, there is a way to give old Mbox1 second live with no computer connected.
All you have to do is make some modification on SMD components - one cut, one jumper around HEF4094 chip. Details:
http://www.zachpoff.com/diy-resource...tandalone-mod/
https://www.gearslutz.com/board/low-...-pre-hack.html
Now, powering with USB power bank you get the cheapest ever field mixer! :)
8 channel audio interface and stand alone preamp alidav macOS 18 03-15-2014 08:32 AM
888 24 Stand Alone Preamp? mikeofsines Digidesign Hardware & Software 2 01-12-2010 10:12 PM
Original M-Box as a standalone mic preamp beyondat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-02-2008 10:11 PM
Can Firewire 410 stand alone as a preamp? Sleep? ktommy Pro Tools M-Powered (Mac) 2 02-08-2006 09:24 AM
002 rack as stand-alone Preamp jbw Tips & Tricks 2 03-21-2004 01:40 PM
