Old 10-09-2019, 09:20 PM
Ienjoyaudio Ienjoyaudio is offline
Default Help. HD Native,HD MADI,SSL Alphalinks,I/O setup
Hello.
My current system is a mac pro 5,1 running HD 11 Native PCI, HD MADI and 2 SSL alphalinks.
I can not get PT to route signal to the second unit. (outputs 33-64) The I/O setup lists the first alphalink as A but the second one as C. The C ins and out are greyed out.
Ive switched boxes around to see if it was a hardware issue but both work in the port 1 position. The port 2 position, which is listed as C does not appear active. @96k the LR boxes are slanted, @44.1 the are not.
I have digilink cables going from port 1 & 2 on the madi interface to port 1 & 2 on the card. Word clock is connected and both boxes lock to sample rate just fine.
Why does PT see the second unit as C and not B. Why is C greyed out. Is there a way to make this work? I don't see why it wouldn't. Screenshots below. Thanks in advance.
Mac Pro 5,1 2.4GHZ 8 core
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
Old 10-10-2019, 12:41 AM
Default Re: Help. HD Native,HD MADI,SSL Alphalinks,I/O setup
Solved
Unplug the madi cables, plug them back in, everything works. Why? No idea.
If only every issue were that easy.
OSX 10.8.5
PTHD 11.3
HD Native
HD MADI
Artist Mix
SSL Alphalinks and Deltalink MADI HD RichR Buy & Sell 0 11-16-2013 01:30 PM
Single-card Native or HDX with MADI Picture Start Post - Surround - Video 2 02-28-2012 12:16 PM
Has anyone tried HDCore Native card with SSL madi interface? SNAZ macOS 0 05-06-2011 04:25 AM
HD Native and MADI for stage Picture Start Post - Surround - Video 0 10-08-2010 10:46 AM
HD-Madi/HD-Native Qs for Tony Cariddi funkcity Pro Tools HDX & HD Native Systems (Mac) 2 10-07-2010 08:18 PM
