Old 01-16-2017, 04:33 AM
MischMaster MischMaster is offline
Default Warp or TCE to selection length?
I'm looking for a solution of warping files to a specific length.
I've got a lot of audio files in 2 languages.
E.g. Track 1 is english and track 2 german.
The german clips begin exactely at the same position as the clips on track 1.
These files are all time critical, so the german files have to be exactly as long as the english ones.
So I'd like to select the english clip on the first track. Then jump down with this selection to track 2 and compress/warp the clip there to the lenght of the clip on track 1.
I prefer a solution only with keys, so that I can automate the workflow with Quickeys, because I've got hundrets of files.
Is this possible somehow?
Or is there another way to get two different clips to the same lenght?
Thanks,
Michael
Old 01-16-2017, 04:41 AM
joachim's Avatar
joachim joachim is offline
Default Re: Warp or TCE to selection length?
HD only :
select english clip
deselect link timeline and edit selection
edit-select german clip
Alt+Shift+U
(TCE Edit to Timeline selection (Pro Tools HD
and Pro Tools with Complete Production
Toolkit only))
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-16-2017, 05:09 AM
Wohoo... this looks good. Working!
Just to be sure I'm doing everything right:
By "edit-select german clip", you mean just click on the german clip to select it.
And after each clip has been processed, I have to reactivate "link timeline and edit selection" and then select the next clip. Then I repeat the whole thing...
Yes... sounds like a plan!
Old 01-16-2017, 07:17 AM
i created a Quickeys workflow and i works fantastic!
Thanks a lot!
Michi
Old 01-16-2017, 08:20 AM
joachim's Avatar
That is what i meant. Isn't that a deal braker for a shortcut script ?
Because a shortcut like "move edit selection down" would not select the "german" clip.
So you programmed a mouse click ?
Old 03-16-2017, 10:53 AM
oh I missed your last answer.
No, no mouse click needed. You can do it with keyboard shorcuts:
Position cursor at the beginning of the english clip then:
shift tab, shift keypad /, alt tab, Ö, shift tab, alt shift U, shift keypad /, tab, P, tab and you are at the next clip and then repeat the whole thing.
By the way... Greetings from Munich
Old 03-16-2017, 11:59 AM
joachim's Avatar
Nice, that works.
Greetings back to Munich from Nymphenburg .
Old 06-27-2017, 06:29 AM
prestonlucy prestonlucy is offline
What a pity I have never heard of Quickeys workflow solution before!
It appeared so easy combining files for my tutoring classes!
Thanks!
______________
essay dune blog
Hotkey for double/half length of selection jschmidtiii macOS 1 10-17-2013 03:20 AM
Default selection length MFPBand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-30-2012 05:09 PM
Copied region length auto-adjust to paste location length? greglawrence Tips & Tricks 4 10-23-2011 01:46 PM
Moving Selection By Selection Length weezerboy Pro Tools TDM Systems (Mac) 14 09-23-2010 04:06 AM
timecode selection length - Pro Tools lies! levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-20-2009 11:01 PM
