Old 04-05-2013, 09:56 AM
asef@me.com's Avatar
asef@me.com asef@me.com is offline
Default Sync IO OMNI HD Native
Hi
Hope help me please
I use pt10 hd native +Omni+ Sync IO
I couldn't understand how I should work with sync IO.
I connected them as a loop sync.
But I don't know which is the correct procedure: Should I set Sync IO first and then from "session setup" set my sessions accordingly? Or all settings must be set in "session setting" and Sync IO automatically gets them from PT?
Old 04-06-2013, 06:08 AM
Drew Mazurek's Avatar
Default Re: Sync IO OMNI HD Native
A few things:
First, you wrote native but you must mean that you have an HD Native card if you're using the Omni.
Second, why do you have the Sync I/O? Are you interfacing with other systems?
Once setup correctly, you would choose Sync I/O in the Session Setup menu
www.drewmazurek.com
Old 04-06-2013, 06:35 AM
Originally Posted by Drew Mazurek View Post
A few things:
Hi
1-Yes I mean HD Native, and I guess that I wrote HD Native!
2-No, I bought it because I must pass 210 and 310 P and I need this device to understand it better.
3-you mean if I set session setup there is no need to set anything on Sync IO device?
Old 04-06-2013, 04:14 PM
When I select my clock Source to "Sync"(Io) and Clock Ref to "loop sync"in session Setup, clock source from Sync will be change to "HD Omni #1 -> internal"
Why?
Old 04-06-2013, 06:51 PM
Originally Posted by asef@me.com View Post
Hi
Hope help me please
I found perfect answer:
SYNC peripheral settings can be controlled in three ways:
1-From Pro Tools
Provides access to most SYNC peripheral controls from within the Pro Tools Session Setup window or the Synchronization page of the Peripherals window.
2-From the SYNC Peripheral Front Panel
Provides access to most controls from the front panel when using the SYNC peripheral in Standalone mode.
3-From the SYNC Setup Software Utility
(Windows Only)
This optional utility provides re- mote access to all SYNC peripheral controls from a supported Windows computer.
Protools 11 HD,HD Native card, Icon D-Command, Omni, Sync IO, Symphony 6.5, Mac Pro
Old 04-07-2013, 02:50 AM
Glad you got it sorted.
www.drewmazurek.com
Old 04-09-2013, 06:50 AM
GuZzB GuZzB is offline
Hi guys!
I just opened a session i've been working on in my other studio in this new set up and PT10 wont find my OMNI HD even tho its working fine in Logic and as the main output for my mac.
Someone please help me !
HD Native + OMNI smfelton Buy & Sell 4 08-01-2013 10:42 PM
HD OMNI / Native Setup! Mvrphy Pro Tools HDX & HD Native Systems (Mac) 3 07-13-2013 10:14 PM
using HD omni with pro tools 10 native? the19thbear macOS 2 04-13-2012 11:55 AM
HD native + omni + aurora 16 sinewavz Pro Tools HDX & HD Native Systems (Mac) 0 01-12-2012 01:45 PM
using Cubase 6 with HD Native / Omni? akhafaji Pro Tools HDX & HD Native Systems (Win) 0 08-24-2011 04:36 AM
