Old 03-29-2013, 05:07 PM
MindDead's Avatar
MindDead MindDead is offline
Default Mbox Mini with HD software?
Is it possible to use an Mbox mini with HD software? My PRE is being sent away and I need a preamp. I can get the MBox mini to work if PT HD is in Protools aggregate I/O in the playback engine. But when I set the playback engine to Mbox mini I get the error "The current playback engine does not support a sample rate of 48k" WTF? I have already downloaded and installed the newest Mbox drivers, so it not that.
Old 03-29-2013, 06:10 PM
TAPSpace TAPSpace is offline
Default Re: Mbox Mini with HD software?
It is possible to use just the Mbox mini with your HD software and license. Your computer will just think that you are using standard Pro Tools with the Complete Production Toolkit.
Just to clarify you are only using your Mbox mini correct? Because I don't think you can use the HD hardware and the Mbox at the same time. Also, just out of curiosity which Mbox mini do you have?
Old 03-29-2013, 06:16 PM
MindDead's Avatar
not using both at the same time. Mbox mini 3rd edition. I get that error when i try to open a session.
Old 03-30-2013, 02:41 PM
Maybe try switching the sample rate in Audio Midi Setup for the MBox before opening Pro Tools?
Old 03-30-2013, 03:39 PM
MindDead's Avatar
Tried that already.
Old 03-30-2013, 09:20 PM
MindDead's Avatar
Also getting this when I lunch protools with the Mbox mini as the hardware device.
http://img51.imageshack.us/img51/247...30330at111.png
Old 03-31-2013, 06:06 AM
Stig Eliassen's Avatar
Maybe this can help?
http://avid.force.com/pkb/articles/e...oductCategory=
Old 03-31-2013, 01:19 PM
MindDead's Avatar
Got rid of the weird long error, by holding N while launching, for now. I'm trying a reinstall to see if that helps with the sample rate error.
Old 03-31-2013, 09:49 PM
MindDead's Avatar
Tried clean install, even tried clean install using the HDX or non-HD option. Nothing & the same errors.
Old 04-11-2013, 10:19 PM
MindDead's Avatar
Well, it doesn't seem to be possible...
3rd gen Mbox Mini no software albee1952 Buy & Sell 0 07-12-2012 03:57 PM
Need software for Mbox 2 Mini / Mac OS X 10.6.8 docr macOS 6 05-16-2012 06:02 PM
Software upgrades from Mbox 2 mini to Mbox 2 Pro? gsguitarest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-07-2010 07:49 PM
What Else Recording Software Can Mbox 2 Mini Go With ? TongWunFung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2008 04:35 PM
using mbox mini with different software (not PT) elphie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-27-2007 09:47 AM
