Old 12-18-2004, 01:54 AM
sjon sjon is offline
Default workflow
I have a question about the workflow from recording to bounce to disk:
When I record my pref.setting says WAV-file, instead of AIFF or anything else. Is that ok?
When boucing to disk I guess I have to choose AIFF, before I burn to disk. For burning I use iTunes.
Is there a better program, or will iTunes do the job?
Hope to hear!
Old 12-18-2004, 07:27 AM
yOkO yOkO is offline
Default Re: workflow
aiff, means:audio interchange file format, an audio file format from apple computers,
while wav, is microsoft audio file format, it depends what you are using it for,(there are other options, sdii, mp3, quik time,etc.)
if you are, say, to make the music or efects for an animation that's gonna be worked in a
pc windows computer, you should bounce it in wav format,(or for sharing it with pc user for any matters)
if your burning to hear it in your cd player any of both will work, you should also choose stereo interleaved.
the itunes can do the job, although i prefer roxio toast, (there are others, you should check the one that better fit your needs).
so what
Old 12-18-2004, 09:54 AM
Thanks. So this means that it also doesn't make a difference if I choose wav or aiff for/when I record?
Old 12-18-2004, 10:43 AM
while pt can read both,
if you're only working in mac only enviroment
aiff is the way to go i supposed.
so what
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 11:08 AM
Workflow pinnacle Pro Tools 10 6 06-22-2012 11:01 PM
3D Workflow weso33 Post - Surround - Video 5 04-14-2011 07:43 AM
MXF Workflow Help! legasafe Post - Surround - Video 2 02-25-2011 07:40 AM
Workflow! kje Tips & Tricks 11 06-26-2010 09:15 PM
