Old 08-29-2004, 01:15 AM
maxx maxx is offline
Default possible to revert from OSX 10.3.5 to 10.3.4?
I just saw the Digidesign warning about OSX 10.3.5 and firewire issues.
I have already (foolishly it seems) done the Mac OS update to 10.3.5 and I have since experienced some Firewire drive issues. In my case it wasn't a Pro Tools specific problem but a basic system issue... certain firewire drives consistently un-mounted themselves for no apparent reason. I was left with the Mac OS error message about dissconnecing firewire drives withpout first properly unmounting them. Is this what Digidesign refers to in their warning about 10.3.5?
What is the best way to restore my system to 10.3.4? Can I just run the 10.3.4 updater over the 10.3.5 system? Or do I have to do a fresh install?
Any thoughts swould be greatly appreciated!
maxx
michael@resonationmusic.com
Old 08-29-2004, 08:25 AM
Vaphoron Vaphoron is offline
Default Re: possible to revert from OSX 10.3.5 to 10.3.4?
You would have to do a fresh install to get back to 10.3.4. I have been running on 10.3.5 since it was released and I haven't had any more problems than normal with my firewire drives.
- Jason
Old 08-30-2004, 08:56 AM
emilano emilano is offline
I also installed 10.3.5 (I have a G5 dual 2 ghz and pt 6.4 HD accel 2). I have had no problems with firewire drives, or any other problems so far. Although, one thing I have noticed is that the key command to increase/decrease the nudge amount (command-option +/-) now does a sort of full screen zoom instead of doing a nudge inc/decr. I think (but im not sure) that this started happening right after the 10.3.5 install. It must be a new key command in the system software that is overidding the pt key command. Its annoying, but its the only problem I've noticed. Still, it was dumb to install 10.3.5 without getting the digidesign qualification...
--E
Old 08-30-2004, 10:01 AM
minister's Avatar
minister minister is offline
you can always go back, using the original disk and choose "archive and install" in the options. that should archive your old system, and install the new one.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 08-30-2004, 12:46 PM
jfredk jfredk is offline
...Although, one thing I have noticed is that the key command to increase/decrease the nudge amount (command-option +/-) now does a sort of full screen zoom instead of doing a nudge inc/decr. I think (but im not sure) that this started happening right after the 10.3.5 install. It must be a new key command in the system software that is overidding the pt key command.
--E
I think you have the 'zoom' feature turned on in System Preferences under Universal Access. It's for visually impaired folks and is quite handy in redeye reduction in iphoto as well.
Anyway, it's the same key strokes (Command+option+=).
Just a thought
JFred in Nashville
G4 MDD Dual 1.42, 2 gig RAM, MAC OS 10.4.11, PT 7.3.1cs8, 192 I/O, Gibson Stereo 79RT
Old 08-30-2004, 01:49 PM
JFred, you rock. Thanks for taking the time to point that out, its much appreciated. That's what it was . Must be that the universal access settings were reset when I installed 10.3.5 or something.
--E
http://www.ericmilano.com
Old 08-30-2004, 04:19 PM
studiojimi's Avatar
studiojimi studiojimi is offline
you are not the only one.
i alway have had those firewire problems in panther
i'm sure they are working on a cs update for 6.1 that will make 10.3.5 cool
it's too bad they won't let us know that it is inevitable
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Ok, tried to revert to 9.0.1 and now can't get PT working asmarti08 Windows 1 04-29-2011 06:29 PM
Revert to 32 bit Windows 7 dogbiscuit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-16-2010 09:38 AM
What is the best way to revert back to 8.01? TheBaron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-20-2010 01:57 PM
Need to revert to 7.0 or 7.1 Bookerv12 Pro Tools TDM Systems (Mac) 1 05-02-2007 07:41 PM
How to Revert to 6.9 from PT 7 lancejorton Pro Tools TDM Systems (Mac) 5 12-25-2005 01:35 PM
