Old 12-20-2016, 07:51 AM
dg27 dg27 is offline
Default Upgrade 11 to 12, and co-install 10 or 11?
My current plan expires in Feb 2017. I downloaded 12 in Feb 2016, but have been using 11 (I never installed 12).
Related to all this, if I remember correctly, don't I have to uninstall v11 before installing 12? And I think you can run v10 and v12 side by side, but not v11 and v12.
And if so, do I have to reinstall all my plugins?
I apologize if these are dumb questions, but early concerns I was reading about v12 were what prevented me from installing it.
I recently added a MIDI controller and want to keep the transition as smooth as possible.
Old 12-20-2016, 11:12 AM
ramonetl ramonetl is online now
Default Re: Upgrade 11 to 12, and co-install 10 or 11?
I only run one version but if I were you and you already have a version installed I would recommend you just do a co install of 12 and move off it as opposed to upgrading. Then import or open your sessions from your desired location. There is no one way, really a matter of what you need. A lot of studio guys may have multiple because they have clients who may come in with alternate version projects and they need to maintain compatibility with the clients home session version. At least so I believe. They could tell ya.
Old 12-21-2016, 09:29 AM
john1192 john1192 is offline
rename PT11 to PT 11.3.1 or something like that .. then PT12 install will not erase them and they will both work ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 12-21-2016, 09:42 AM
sw rec sw rec is online now
Most common co-install is PT 10 (do that first) and PT 12. There's really no need to run 11 and 12 both....good and stable on PT 12.4HD/Win 10 here.
Old 06-26-2017, 03:22 PM
I have been putting off installing PT 12 for quite a while and will finally try and do this in the next week of so. There are a couple of plugins I'd like to use that are 12 only.
I'm currently running 11.3.0 and would prefer to leave that installed if I can, just in case. (one of the reasons I haven't installed 12 is that 11 has always worked very well for me).
Regarding this:
Where would I rename it?
Old 06-26-2017, 03:40 PM
Regarding this:
you rename the Actual Application (only works on a MAC) ..
File Type: jpg Screen Shot 2017-06-26 at 2.39.35 PM.jpg (26.4 KB, 0 views)
Old 06-26-2017, 03:58 PM
Thanks for the clarification.
I'm on Win 7 Pro 64 bit.
Edit: Just found this:
http://avid.force.com/pkb/articles/e...ll-Information
I guess this means in Windows I cannot have both 11 and 12 both installed, correct? I remember reading this a while ago.
I have everything backed up redundantly, but I really wish I didn't have to uninstall.
I will have to read up on that Trasher program; I think I need to use that.
install upgrade from pt 11 to 12.5 keithl Pro Tools 12 5 09-03-2016 10:41 AM
Upgrade from 7.3 LE to 10.. Do I have to install 7.3 LE first ? ilovemusic Pro Tools 10 4 10-27-2012 12:16 AM
7.4 upgrade which VST's should I not install peter kuchar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-10-2007 08:11 AM
Should you install every new upgrade? ishur Pro Tools TDM Systems (Mac) 4 05-11-2006 08:21 AM
need help with install/upgrade tromba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-23-2004 08:27 AM
