Old 01-09-2014, 10:17 AM
Default Running PT 64 Bit only yields 32 Tracks??
So a HDX1 with just an Avid MADI interface connected to it, nothing else?
0. How exactly are you determining what IO is available?
1, What exactly is the playback engine set to?
2. What is the Setup> IO showing? What happens if you default all the IO?
3. You have two Digilink cables currently connected (32 IO per TDM cable as always...) and you can really start Pro Tools 10 and 11 now and you see a IO difference right now (not in some past test?)
4. What sample rate are your sessions at?
Old 01-09-2014, 11:02 AM
teacherman teacherman is offline
Default Re: Running PT 64 Bit only yields 32 Tracks??
My input source into the HD MADI is via MIDAS PRO Console with 64x64 stage boxes. (2) DigiLink cables connected from the HD MADI to the HDX PCIe card.
Playback engine = HDX
In both PT 10.3.6 and PT 11.01.1 sessions--ProTools I/O setup shows 64 inputs (2 banks of 32).
Under PT 10.3.6, the session is seeing 64 channels of input.
Under PT 11.0.1, the session is only seeing 32 Channels of input...even though the PT I/O setup shows 64 inputs available.
Session is at 24 bit/48 Khz.
MacBookPro 2.2 Ghz Intel Core i7; 16 Gig Ram; OSX 10.12.6; ProTools 10.3.9; Protools 2019.6
Old 01-09-2014, 11:05 AM
YYR123's Avatar
YYR123 YYR123 is offline
Nevermind
Daniel
Old 01-09-2014, 11:33 AM
Again I am lost by what you mean by "seeing" if the Setup>IO shows 64 channels of IO (and you did default them all right?). Then what exact symptom/what exactly happens that says you do not have 64 channels? Not able to assign an input or output to a track? Not able to hear an input or what?
What clock rate is the console driving MADI at? Please check, and it can be different than the session clock rate. And have you actually checked both the session clock rates, you are not just assuming it is 48 kHz?
And confirm you can switch back and forwards now between both Pro Tools 10 and 11 and this is currently happening.
Old 01-09-2014, 11:57 AM
Craig F Craig F is offline
I think it's time for some screen shots so we can see what you're seeing
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-09-2014, 12:06 PM
bashville bashville is offline
So running PT11, you see all the inputs you want in the I/O setup (across the top of the setup box from left to right). Did you create inputs and outputs in the respective ins and outs tabs? (Up and down list to the left). Sorry to state the obvious, but let's get that out of the way. Your inputs won't show up in the track pop-up selection boxes unless it's configured with a name in the I/O section, which is separate from seeing it as available hardware.
HD Ultimate (Native), PT2019.5, 192, 3.2 Quad MacPro 5,1, 16 Gig, Sierra
Old 01-09-2014, 12:09 PM
Yep time for screenshots...
Drew Mazurek's Avatar
No, that's the way the Icon defaulted when I installed PT 11. The new icon has the Protools logo + a big ole "64" stamped on it.
New one to me. Never seen a "64".
www.drewmazurek.com
Old 01-09-2014, 12:31 PM
OKAY..thanks for everyone's time on this.... Though, I just found stumbled across the problem and now the issue is resolved..
The problem was... that under the HARDWARE SETUP in 11.0.1, the "MADI Routing" was incorrectly set to "split". Once I changed the MADI Routing to "Normal", all 64 inputs came into PT.
Again, thanks for everyone's input.
Later,
Old 01-09-2014, 12:34 PM
Sigh, let me guess... http://www.pro-tools-expert.com/home...-on-a-mac.html
(And no, changing the icon back will not fix the problem )
Bounce to Quicktime Movie yields only a .wav, no video saspro Pro Tools TDM Systems (Mac) 0 02-15-2010 04:26 PM
import session data yields sends at 0dB Mark Dann Pro Tools TDM Systems (Mac) 0 01-22-2007 08:37 AM
Export MIDI yields lots of nothing in PT7 EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-18-2006 01:43 AM
"Bounce to Disk" yields a slow and low-pitch song pborkstrom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-30-2003 08:25 PM
Which USB floppy yields the LEAST HEADACHES! Boom Chic Pro Tools TDM Systems (Mac) 11 10-16-2002 01:11 AM
