Old 11-22-2012, 04:54 AM
Izeniel Izeniel is offline
Default Multibridge Eclipse Blackmagic Design
I'm using a weird config at my work and I only have a Multibridge Eclipse from Blackmagic design as an audio acquisition card.
For the first time in need to use the 4 analog inputs and I can't see them in pro tools.
Old 11-22-2012, 03:33 PM
crizdee's Avatar
crizdee crizdee is online now
Default Re: Multibridge Eclipse Blackmagic Design
If you go to the setup / hardware setup page. and on the inputs tab can you set the inputs 1-4 for analogue?
similar to this picture except inputs 1-2 and 3-4 should be set to analogue...
http://huseac.fas.harvard.edu/FAQ%20...hs_aes-ebu.png
Also in the i/o setup page on the inputs tab you can create extra inputs (New path) and assign them to the analogue inputs on your interface?
similar to this pic (Except this is using a 192 interface)...
http://support.apogeedigital.com/hel...t_io_setup.jpg
Once that is done they should be available as inputs on your tracks!
If the above does not work!!...
Next thing to look at would be your AMS (audio midi setup)? in applications/utilities. and see if the interface is showing and set to use all inputs etc.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-16-2013, 10:46 AM
bauhausestudio bauhausestudio is offline
Contact just because you could tell me if the card "blackmagic Multibridge extreme" is compatible with Pro Tools HD9 and use it to send the video signal from the "timeline" as television monitors ..
The truth is that I was also considering the option of "intensity" but which option would be best if the two were compatible ..
Thanks!
Blackmagic Design MultiDock John_Toolbox Storage Subsystems 0 08-26-2013 09:43 AM
Blackmagic Design Intensity Pro issues PT user Post - Surround - Video 8 12-05-2012 06:31 AM
Pro Tools 10 on Intelmac with Blackmagic Design Intensity Pro anyone? haifai macOS 1 11-28-2012 05:20 AM
Blackmagic Design Thunderbolt shuttle?...how is it with Pro Tools for video? PT user Post - Surround - Video 0 05-10-2012 03:45 PM
Eventide Eclipse: Any good if you've got plugs? syra Pro Tools TDM Systems (Mac) 11 03-31-2003 09:43 AM
