Old 04-27-2014, 10:37 PM
garyth garyth is offline
Default Please help!
So I've purchased PT 10/11 after using Reason for quite a while, thinking this would be the next big step in recording.
I've faced nothing but frustration so far learning this new DAW and I have some questions... Hopefully someone here can help me out!
So in Reasons flex tempo is really amazing. For example, when laying down a guitar clip that's a bit too complicated to get perfect, you can decrease the tempo to where it's easier to play, and then readjust the tempo to the original BPM. It then plays the clip in the same key and tempo as everything else and sounds really great. It's a simple process.
NOW in pro tools, it's so much more complicated to me. I've searched and found a method to doing it, but there are so many steps that really stress my workflow. Can someone suggest a simpler method?
Thank you so much!!
Old 04-27-2014, 11:46 PM
Shan's Avatar
Shan Shan is offline
Default Re: Please help!
Welcome to the forum garyth. In brief:
  • Enable elastic audio on the track. In my example I set it to polyphonic.
  • Change the Timebase selector to Ticks(the green metronome icon).
  • Double click on the red diamond icon in the Tempo ruler to change the base tempo.
Your audio track will now follow the base tempo changes. Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 04-28-2014, 05:37 PM
Shane
This is great advice! Thank you; you have solved my problem.
