Old 04-25-2011, 02:08 AM
AtomicLongie AtomicLongie is offline
Default Hmmm, I cant move things about in my edit window. Any ideas?
Hi Guys and Gals,
I'm very new to Pro Tools so please forgive me if this is a rookie error...
I'm in the process of making a soundscape using recordings that I have take on a field recorder. I'm currently about 3/4 of the way through arranging my sounds in the edit window, but suddenly Pro Tools will not let me drag blocks of audio around, instead I am having to cut and paste them into the places that I want them to be in (as you could imagine, this is very annoying and makes editing more difficult)
Does anybody have any ideas what I have done wrong? Have I accidentally knocked something that has turned the ability to drag things off?
Any ideas would be much appreciated!
Old 04-25-2011, 03:21 AM
jntracks jntracks is offline
Default Re: Hmmm, I cant move things about in my edit window. Any ideas?
you can lock regions in place, i forget the key command...
try holding cntrl while dragging. that's the general "bypass grid or group lock" key.
-j
www.jntracks.com
Old 04-25-2011, 10:38 AM
HD2 HD2 is offline
Check what mode you are in. It sounds like you may be in shuffle mode. You need to be in slip or grid. Selection is in the Top left corner of the edit window.
Old 04-25-2011, 12:27 PM
Thank you so much!
I knew it'd be something stupid!
You're stars!
[IMG] code is Off
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 03:20 PM
Locked - Cannot use selection tool anywhere in edit window or move clips! eneedham macOS 30 05-05-2012 08:23 PM
Clicking in Edit window does not move playback marker...help! Lofty11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2009 09:01 PM
Breakpoint move line in edit window:How to disable TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-12-2007 12:36 PM
How to move things up and down in a mix? d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-22-2003 12:23 PM
